Part # needed --sbf oil filter
Discussion in 'The Hokey Ass Message Board' started by Crankhole, Apr 13, 2007.
  1. Crankhole
    Crankhole
    Would someone happen to have a part # for a short oil filter for a sbf? Putting a 302 in my shoebox and am having a small clearance issue. Thanks
  2. blpug
    blpug
    from Ma.
    Try Motorcraft #FL # 300
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Don't have the part number but the application is MOPAR. Shorter than a standard FL1 filter but an inch or so.
  4. CruZer
    CruZer
    They make a short and a long spin on for the SBF.Fram makes them,Walmart sells them.
  5. Flat Ernie
    Flat Ernie
    Tech Editor
    You have two other alternatives to running a shorter, potentially less effective filter.
    Get the 90* Motorsports adapter & swing your filter to wherever you have the best clearance.
    If that doesn't work, run a remote filter.
  6. Crankhole
    Crankhole
    Somehow I doubt that the clerk at Walmart will be able to tell me which one I need. But, where can I get one of those 90* adapters if it comes to that?
  7. buford36
    buford36
    from Maine
  8. Crankhole
    Crankhole
  9. bsharer
    bsharer
    from Texas
    FL1A = 5 9/32"
    FL300 = 4 11/32"
    FL842 = 3 31/32"
    I had to run a smaller filter on my 302 in my Fairmont to clear my downpipe. I am using the FL842 on a factory Ford 90* adapter. The adapter is PN M-6880-A50.
  10. George
    George
    Standard lenth (FRAM #s) is PH-8A, shorter(usually used on Mopars) is PH-43, shorter still is PH-16. The PH-16 is shorter than the catalog equivelent from Motorcraft or Wix. The 90 deg. adaptor is 55$ new from Ford Motorsports, can be used on Mopar, & Mopar Performance wants something like 125$!
  11. SlowandLow63
    SlowandLow63
    from Central NJ
    I know em in Penzoil. The standard SBF is PZ-1, you're lookin for PZ-42, its about half the length. Group 7 number - V4651
  12. dave lewis
    dave lewis
    from Nampa ID
    there is a marine filter ( fits volvo, mercruiser etc. ) that is less than 2" tall.. the part number escapes me, but your local napa counter man (not kid) can look in the book and find it for you.. the ford uses the most common thread / gasket size in the world.. heck, even some ferrari spin on filters use the same base !
    used the shorty to solve clearance issues several times.. just change your oil more often to make up for less filter area..
    good luck
    dave :D
  13. Pooch
    Pooch
    from Oklahoma
    NAPA 1515 big filter
    NAPA 1085 short filter
