Hot Rods Parts fit ???
Discussion in 'The Hokey Ass Message Board' started by larry k, Jun 3, 2018.
  1. larry k
    larry k
    i can't find this part number in my Chevy parts book!!! So what does it fit , -3973456 flywheel 168 tooth.
  2. TagMan
    TagMan
    That number is a casting number, not a part number, which is probably why you couldn’t find it in your parts book.
    That flywheel fits a several Chevy models 1966 & up including Camaro, Nova, Chevelle etc. with 350, 396 & 427 cu. in. engines. Diameter is 14" 168 tooth. Uses 11" clutch. This flywheel is correct for internally balanced V-8's as listed above and is not intended for a 454 cu. in. engine.
    pitman, 31Vicky with a hemi and pat59 like this.
  3. larry k
    larry k
    Well thanks for your help tag man ! By the way , what is the part number ??
  4. theHIGHLANDER
    theHIGHLANDER
    I have the same one. I think it's 397-0U812...;)
    325w likes this.
  5. larry k
    larry k
    Man you yanks up north must have a different parts book than us Rebs do ?
  6. pitman
    pitman
    Closer to GMC, or Zora!
  7. Fordors
    Fordors
    P/N for Chevy with 11” clutch is 3998281, all except 400 sb and 454. Obviously no longer in GMPD system.
