Parts source needed: '37 Ford
Discussion in 'The Hokey Ass Message Board' started by raven, Oct 11, 2007.
  1. raven
    raven
    Alright, I just picked up a '37 Ford coupe.
    I'll be needing some parts for it so I thought I would ask for resources for repop parts.
    What's out there?
    r
  2. Django
    Django
    from Chicago
    C&G Early Ford
    Dick Spadaro Early Ford
    Bob Drake
    Dennis Carpenter
    and probably a slew of others.
  3. Short answer - Anything you could ever need.
    Contact:
    Dennis Carpenter
    Bob Drake
    Midwest Early Ford
    Dick Spadaro
    JH
  4. Django
    Django
    from Chicago
    Jinx! Hahaha.
    what are you looking for Raven?
  5. chevnut
    chevnut
    from Corona, Ca
    notch kit from Gambino
  6. raven
    raven
    Well, most of the interior parts, glove box door, ash tray, guages ( I have a speedo), a rear seat for it (I know it didn't come with one), exterior door handles, good bumpers (the chrome's gone on mine), trunk latch and handle, gas tank, dropped front axle, a four-bar set-up and some form of 'instructions' as to how it goes together...:)
    r
    Oh and I need a cowl vent, too...
  7. hammeredabone
    hammeredabone
    Hey Raven,
    If thje ashtray out of a 38 pickup will work, pm me your addy and I will send it to you.
    Gordon
  8. raven
    raven
    I don't know if the pick up and the car dashes are the same.
    Can anyone answer this?
    Oh and it they are...THANKS!
    r
  9. I don't know about the PU & car ash tray...... but I'm betting "no".
    Go to Ebay Motors & save a search for "1937 Ford" most of that little stuff you need is listed all the time & much of it sells rather cheap.
    As for 4 bar kits, you don't need one. If you're running a stock (or '39) trans, you don't even have to split the stock wishbones. If you swap the trans for something newer (which will most likely = larger) then you just need to split the stock wishbones.
    Chassis Engineering has a nice kit for this.
    JH
  10. Let us know what year your wishbone is before you buy an axle....and if you're planning on splitting it. A '35/'36 wishbone & a later wishbone have different measurements between the perch pins.
    If you're splitting the wishbone this isn't as much of a concern. If not, you have to be sure your axle & wishbone will work together.
    JH
  11. 50flathead
    50flathead
    from Iowa, USA
    Most of what you list is available from a variety of sources. It would be nice if reproductions of the 37 glove box door, ash tray, and radio hole cover were available. This stuff shows up here and there but are scarce.
  12. rat seeker
    rat seeker
    I am also working on a 37. I wish I could figure out about posting pics so you could view. I installed a complete chassis engineering dropped axle and rear suspension kit. Shoot me you email and I will send some pics.
  13. raven
    raven
  14. raven
    raven
    Thanks. that one works.
    What width rear end do I need for this coupe?
    Also, what would one suggest for a daily driver:
    1. Transverse spring with reversed eyes
    2. Parallel leaf with sway bar
    Also...
    1. Split bones up front
    2. Four-bar up front
    r
  15. For a daily driver, if it was mine...........
    Parallel leafs & split bones.
    JH
  16. raven
    raven
    OK, stupid question time.
    Can I use split bones with a dropped axle?
    r
  17. Yes, & you'll save the cost of a 4 bar kit in the process.
    JH
  18. raven
    raven
    Alright Harrison, you've convinced me.
    I'll have a four-bar set up in the classifieds soon.
    r
  19. Django
    Django
    from Chicago
    Good choice.
    What motor? Then I'll tell you what rear end. :D
  20. autoartistry
    autoartistry
    I have alot of leftover parts from a 37 Ford 4 door I built.I did not use much of the original parts.Some of the items I know that are left--
    ashtray
    Outside door hinges
    hood ornament
    rear view mirror
    chrome grill trim
    all window regulators
    frt seat complete
    windshield wiper motor
    rear window shade
    many misc including original motor and transmission
    Car only had 15000 original miles on it...
    pm me for more info.
    Mike
  21. Raven PM'd me & said he has a 283 for it.
    JH
  22. Petejoe
    Petejoe
    from Zoar, Ohio
    Raven,
    No parts to offer anymore but give me a yell if you have any assy questions. I can help. Glad to see another 37 coupe here. Not too many around on the Hamb.
  23. raven
    raven
    Well, yesterday, I picked up the power plant for my 37.
    How's this?
    1957 283 with power pack heads and a factory four barrel in running condition, oh and the factory three speed with a Fenton sgifter still attached. It's reputedly out of a '57 Chevy car. Now I need a flywheel and bellhousing. Oh and a finned aluminum oil pan and vintage Cal Custom finned valve covers.
    I didn't plan on starting this project yet...
    r
