patriot cylinder heads
Discussion in 'The Hokey Ass Message Board' started by 66nova383, Aug 21, 2010.
  1. 66nova383
    66nova383
    Anyone here have experience with patriot cylinder heads?
    I am building a small journal 327 with 10.5 to 1 cr and a doug nash 4+1 to back it.I sure could use some input on head selection
  2. boones27t
    boones27t
    from redding ca
    ive heard they are crap but no first hand knowledge...
  3. BrandonB
    BrandonB
    from nor cal
  4. yekoms
    yekoms
    Nope...I have no reason to use Patriots. Brodix and Edelbrock are real good quailty.
    Smokey
  5. 8FLEET9
    8FLEET9
    from MASS.
    i used them on a 355 chevy i put together a few years ago. no complaints. excellent product for the price.
  6. 47chevycoupe
    47chevycoupe
    from Finland
    A guy I work with bought a set, returned them as the quality was not the best. He bought a set of darts.
  7. tgabbe1934
    tgabbe1934
    from smithtown
    They are ok, I have a pair on my big block. The components are not great quality, I would not use them race engine, but for just regular tooling around they are just fine. A decent product for the money in my opinion. Good luck
  8. spoons
    spoons
    from ohio
    spend the money on something worth while...
  9. coupemerc
    coupemerc
    You may want to pm "Littleman". I believe that he ran them on his truck a while back. He found all of the weak links.
  10. ol green
    ol green
    At the shop I used to work at we used there heads alot till we got 3 pairs with the wrong size valve seals, I would look at some other brands myself(Edelbrock/Trick Flow/Dart)
  11. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    The set of Patriots I attempted to run...in the end..........would do a better job as book ends....The valve seats would shift...the castings ..well I have nothing nice to say about them.....I will suggest you save up a little more doe and lay it down on a set of Darts, AFR's and others that have been suggested above.....Spend your money once !.........The Patriots will survive on a StreetRod, but a real HotRod you may be flirting w/ trouble.....Now keep in mind I was Drag Racing w/ them and they did not hold up to the 7,000 + RPM's I was throwing @ them.....maybe I had a bum set ?....I ended up buying a brand new set of AFR's..Great castings, great parts used in the assembly and cnc ported...and all my troubles went away after I first fired it w/ them on.............Goodluck, Littleman
  12. gasser38
    gasser38
    I've used one set on a 383 we built. OK for the money. I agree with the other guys that they're OK for something mild but for big power try something else. The 383 made 430hp with them. One issue we had when it went in the car was that the accessory holes were drilled a little off. Other than the benefits of being aluminum, you'll do just as well with a set of vortecs for a little less money. The vortecs will pull off the 10.5 compression without detonation if you tune it right. The patriots will be more forgiving with the 10.5. Shouldn't have any trouble at all.
  13. pex
    pex
    from alberta
    I just had the weekend from hell because nowhere is it mentioned that you need a oversized intake gaskets to run a victor jr or preformer intake on these pcs of shit.
  14. 390Merc
    390Merc
    from Indiana
    I'm running a pair on a mild 355 sbc for about 3 years now and have been pleased with the performance and everything so far, but it is not a race car and I bought them mainly for looks and a slight performance improvement. I sanded the smooth ends of them down and polished that part. I bought mine from a performance shop in Kingsport, TN that used to sell them on ebay. I think they checked them out fairly good before selling them.
  15. I would suggest a "Google" search on these .....
  16. Deuces
    Deuces
    I'm running a set of Trick-Flow "Twisted Wedge" heads on my 352 Windsor roller motor... That car is too brutal to be running it on the street.. :D:D:D
  17. I was curious about 'em also.. But 'Google' says, I shouldn't be!
  18. A friendly suggestion, tell us your budget, and we can make a good recommendation other than Patriot based on that. No sense throwing out the names of all the great heads out there if you are not willing or unable to spend the money. Many good names have been mentioned, but if you only want/or are able to spend $800, no sense in naming the $1200 offerings.
  19. oj
    oj
    I worked on one of thier engines - yup they make engines too - i had to put adjustable pushrod guide plates on them because the rockers didn't line up with the valves. I took pics and they refunded the customers' money. It had roller rockers and 3 of them were half off the valve, the rocker stud was not drilled where it was supposed to be and that threw the rocker out of alignment.
  20. FWIW, you wont know the static compression ratio until you have the heads and the combustion chamber size at hand.
