Hot Rods PAW catalogs?
Discussion in 'The Hokey Ass Message Board' started by 56sedandelivery, Mar 8, 2021.
  1. 56sedandelivery
    56sedandelivery
    I'm pretty sure most of you remember the old PAW catalogs of performance auto parts. I even bought parts from them, and that's really what this thread is all about; I need some help if any of you have one of these catalogs lying around. Years ago, I bought a SBC, flat tappet, solid lifter camshaft and kit, that is in my "spare" 327. Somewhere along the line, I must have thrown out my PAW catalog, and now I need one. And, I can't find the cam card that had the specs for this cam; I especially need that to set the valve lash. The camshaft was a Super Stock Industries ("house brand" of PAW???), part number SSI 10342. The last car the 327 was in was a 1963 Chevy II station wagon, with one of my own, beefed aluminum Powerglide transmissions, a 4500 RPM stall torque converter, and a 4.88 geared, Positraction rear end. It all made for a nasty little sleeper. The engine has sat for some time now, in a heated garage, with the rocker arms backed off. Can anyone help?
    I am Butch/56sedandelivery.
    alanp561 and chevy57dude like this.
  2. Mike VV
    Mike VV
    from SoCal
    The cam card info won't be in the catalog, at least I never saw that in my old catalogs.
    Gonna need to find out who did the cam grinding. I've been in the last two shops that they had, never saw any cam grinding equipment.
    As a guess, being more of a "race" (?) cam, I'd give .022" int., .024" exh. a try.
    Experiment from there for the best performance.
    Mike
  3. Bob Lowry
    Bob Lowry
    cam.JPG Here you go: Gross lift is .488, 112 loc, .030 - .030 valve lash hot. Price was 44.95. Bob
    From their 2005 Catalog
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    IMG_20210308_150110.jpg IMG_20210308_150110.jpg Beat me to it !
    alanp561, AHotRod, Deuces and 4 others like this.
  5. Ericnova72
    Ericnova72
    from Michigan
    Wow! 277° duration @.050" lift...that's a monster amount of duration in a little 327....and only .488" lift?
    Must have been intended for stock heads(or stock-ish)
    I like the #10343 a lot better.
    #10396 is a rough copy of the 2nd design GM "offroad" camshaft.
    Would not have guessed the majority of their solid SBC cams to be such loose lash, at .030".
    GlassThamesDoug likes this.
  6. jimmy six
    jimmy six
    Back then saying 30-30 meant something...PAW was great and I could drive over to get parts. My son and I did his first engine using PAW...
  7. Bob Lowry
    Bob Lowry
    Yep, it was awesome to have catalog as big as the old yellow page directory, just for GM parts, too. And then you could get one for Fords...way cool. You could look at all of the major suppliers products and make an educated
    buying decision. Bought their complete SBC 671 Blower set up. Couldn't have been happier with it. Glad I saved
    the catalog to reminisce.
    egads and Deuces like this.
  8. 56sedandelivery
    56sedandelivery
    THANKS guys!!! I was thinking the valve lash was .018 intake/.022 exhaust for some reason. I knew the lift was somewhere around .480+, but the 316 duration and 277 duration @ .050 surprises me; explains the idle for sure. Old school cam profile. I'll have to have this info tattooed on the backs of my eyelids so I don't lose it again. I'd initially posted this over on HotRodders.Com, for ericnova72, and he suggested posting here also; should have just posted here to start with. As far as "stock heads", well that's actually a little off; old school ported and polished/2.05-1.60 stainless, tuliped valves/pinned studs (said they were old school)/spring-retainer-keeper kit/Harland Sharp roller rockers. This is actually the very same engine, but with a cam change, that was in my FED in the late 70's/early 80's, with a best of 9.23 ET @ 146 MPH. Stock 340 HP/L-79 short block with a cam change, the already mentioned 461 X heads, Holley 300-25 intake and 750 DP Holley, Single point distributor, ****** up swept dragster headers/Powerglide with a trans brake, and a 4500 RPM stall converter, 4.10 Pontiac-open rear end. Econo/bracket dragster I built for less than $4000.00, including the trailer/fire suit-helmet. The engine, with a change to a hydraulic cam, went into my DD P/U truck for a while (where it burned an exhaust valve), and then later on, into my 63 Chevy II station wagon/street racer, with this cam slipped into it. The engine was freshened up some 25 years ago, has sat on the engine stand, with the rockers backed off, and in a heated garage. Hopefully, it goes into the sedan Delivery this summer; I need MORE POWER (as Tim "The Tool Man Taylor would say)! THANKS AGAIN guys!!!
  9. 56sedandelivery
    56sedandelivery
    I think the reason the full specs are posted in the catalogs, on these SSI cams, was because they were PAW's "house brand cams". I also had the sales slip from PAW, so I had the cam number. I'll probably find the original cam card now that I've gotten the specs. I am Butch/56sedandelivery.
    5window, Bob Lowry and Deuces like this.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    PAW catalog makes summit/ jegs catalog look like sale flyers ! Good Lord , how we've changed !
  11. 56sedandelivery
    56sedandelivery
    Those PAW catalogs were what dreams are made of; too bad they are no longer. They could probably come back as an online store. California Discount Warehouse was another one; I think they are still around, only deal in just hemi stuff and only on E-Bay. I am Butch/56sedandelivery.
    Glenn Domm and Deuces like this.
  12. Bob Lowry
    Bob Lowry
    A view back in time...a complete blower setup, just add an oil pan, carbs, oil, and torque wrench....2005 pricing.. Good stuff!
  13. rudestude
    rudestude
    If you want to see parts prices that will put a lump in your pants you need to look through some old ones like these.
    Even with the cost of living differences and a guys ernings its still shocking. 20210310_032858~2.jpeg 20210310_032917~2.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    Bob Lowry likes this.
  14. 5window
    5window
    I see a '67 catalog there. In 1967, a Shelby Mustang 350 coupe cost about $4000. That is roughly $32000 today, Not bad but the median household income in '67 was $7200 so not much has changed.
    Bob Lowry and rudestude like this.
  15. junkyardjeff
    junkyardjeff
    I thought they were gone long before 05.
  16. milwscruffy
    milwscruffy
    They were around after that dealing strictly with early Hemi parts and engine kits.
  17. junkyardjeff
    junkyardjeff
    I have not seen one of their catalogs since the late 80s.
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    A 2021 mustang GT 500 lists at $72000 ....apples to apples
    Median wage is $65000
  19. Not to mention
    higher tax brackets !
  20. Thomas whitby
    Thomas whitby
    Any way you the specs must be on page before the one on top starts 10314 I need specs for 10312
  21. 55blacktie
    55blacktie
    Firstly, .030 hot lash sounds excessive to me. Secondly, 277 degrees duration @ .050 lift also sounds excessive for a street-driven 327. Finally, the numbers won't help with degreeing the cam; you need to know opening & closing events. Personally, I wouldn't consider using that cam in anything other than a race-only car, and if that's the case, there are better choices. For the street, you'll be happier with a duration @ .050 lift of 240 (or less), but I wouldn't run 488 gears on the street either.
  22. 2Blue2
    2Blue2
    Ah, the good ole days...
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I hope I'm not putting a nail in 56sedandelivery's coffin if he's still with us. But hasn't he p***ed away?
  24. saltflats
    saltflats
    from Missouri
  25. Members responding to a 1-1/2 year old post with out looking.
    Johnny Gee and Jalopy Joker like this.
  26. 55blacktie
    55blacktie
    Dang! I could have spent my 2 cents elsewhere.
  27. SS327
    SS327
    I miss Butch and his wisdom.
    427 sleeper and irishsteve like this.
