Technical Paxton Dummy...
Discussion in 'The Hokey Ass Message Board' started by rjonst, Jan 16, 2016.
  1. rjonst
    rjonst
    from Virginia
    The carb has been re-jetted back to standard operation.... Other than no "Oomph", what would be the ramifications of removing the impeller on a Paxton SN-60. Objective is to leave the mechanics in place and run unsupercharged.
  2. Chili Phil
    Chili Phil
    Umm, the ramifications would be lameness.
  3. Ramifications might be extreme piss-taking on The HAMB. Beyond that it would be like having a vast plenum chamber.
    falcongeorge likes this.
  4. Rusty O'Toole
    Rusty O'Toole
    For testing purposes you can take off the drive belt and the hose from the blower. If you mean permanently take everything off including switches, electric fuel pump, brackets,pulleys, hoses and carb top and send it to me.
    Taking out the impeller would be a bad idea. The blower would still be too big a restriction. Just disconnect or take it off.
  5. el Scotto
    el Scotto
    from Tracy, CA
    I toasted a modified McCulloch I had on a 283, I just took the thing off and set it aside to play with later. All the blower drive stuff comes off easy too.
    Why not do that?
  6. X38
    X38
    I could speculate...
  7. Nailhead Jason
    Nailhead Jason
    If you don't want a blower I'll trade you a tripower or dual quad set up to replace it. PM if your interested.
  8. Nailhead Jason
    Nailhead Jason
    I'm in VA like you. So I can bring it to you.
