Pay it foward = free parts for HAMB members
Discussion in 'The Hokey Ass Message Board' started by axeman39, Mar 18, 2008.
  1. axeman39
    axeman39
    from Saco Maine
    Hey guys and gals, I just wanted to say thanks for making this whole free parts thing work, I was hoping it would take off way back when I put that Hemi fuel pump up for grabs 14 pages ago!! Just glad to see it still working. Thanks, Axeman.
  2. A Little Odd
    A Little Odd
    Could you PM me with the rest you got?
  3. CadDaddy42
    CadDaddy42
    Cool thread - wish I'd have seen this sooner. I'll chip in.
    Some barely Hamb-friendly bits leftover from my truck...
    - Ford 360 FE almost complete free for the taking. Came out of my '70 F250 before I got it. Left open for a long time, so full of dirt and shop grit, etc, but supposedly was pulled due to a flat cam and lack of cubic inches. Valve train all there, plus a few new pushrods, basically a complete engine less carb and dizzy. Does include valve covers and oil pan. Not the most desirable casting numbers, not a 390 or 352, but lots of good stuff still on it usable on either. If anyone needs a specific (small) peice, PM me and I'll pull it for you if no one takes the whole thing.
    - 2 C6 cores. 1 late model w/ shift indicator switch, one FE (the original one from my truck). Both have burned up rear drums from the damaged valve body in the early case...
    - FE headers - ****** Super Comp - supposed to fit the truck. Actually have 2 pairs, the other set looks almost identical but no 'Super Comp' tags.
    - 1 almost new C6 converter (needs flushed...)
    - several (3 or 4 I think) Motorcraft 2 barrel carbs in a box
    - FE 2bbl carb heater
    - Hood hinges for '67-'72 Ford truck
    - Wiper arms for Ford truck
    - driver's window regulator for Ford truck (works but a little sticky - teeth OK)
    - V-belts (not for Ford engine, I don't think). All brand new, don't know what they fit.
    - Duralast 15530 / 11AV1345
    - Valuecraft 15470 / 11AV1195
    - 15430 / 11AV1090
    '11'= 1.1cm wide (~1/2").
    '1345', etc = mm length (25.4mm=1 inch) I post for free, you do the math :)
    Some more HAMB-friendly bits...
    - 1 pair of '64 T-bird door handles (decent chrome - VERY minor pitting in 1 small area) and 1 pair of good vacuum power lock actuators (working). Will post pics when I get time to pull them out and take some.
    - 1pr '73 Sedan Deville fender skirts. Latches, hooks, etc, everything normally attached to the skirts (except maybe the lip trim - can't remember). yellow. Heavy duty hardware for big skirts (like custom bubble skirts...). You can cut these down to fit within your wheel opening, then build the bubbles onto the outside of them. For those of us who are not master fabricators, but want to set up our own bubble skirts...
    That's just the stuff I've been tripping over :)
    Cleaning my garage a little this weekend...
    I'll ship anything for shipping / packing materials cost (from work, I can ship anything as long as I pay for the packaging materials and shipping costs). I'll use used (free) boxes, etc, where possible, of course. The big stuff is probably going to cost more than it's worth to ship, unless you really need it and can't get it locally.
    If anyone has a '54 Caddy driver's headlight bezel, bucket, etc, or the trim piece right below the headlight up for grabs, or a gold center cap for OE gold anodized aluminum spoke wheels or a chrome center cap for OE chrome wire wheels, put me in line.
  4. cfnutcase
    cfnutcase
    from Branson mo
    OK I will post a want in here, I am needing a set of 49 or 50 lincoln taillights, I dont care if they are pitted up or whatever, looking for some to go in my new merc project! Thanks, Jim
  5. CadDaddy42
    CadDaddy42
    If this is still available, can you measure it for me (length / width)? Thanks.
  6. crackerass54
    crackerass54
    from dallas
    someone got the skirts, i'll get yall a better list in a day or two
  7. I have 6volt parts, gen. reg. light bulbs, head lights etc. even a fairly new 6v battery, from my '55 Ford 272, all parts work...if your in Central or No,cal. we can hook up and you can have the whole lot. would be tough to ship but could be done, except battery.
    Need '32 Ford truck parts, mainly bed, see pics on Drugasm profile or FE stuff.
    Thanks.
  8. Awsome thread.. here's what i got.. four speed Ford truck ****** off of a Yblock.. it's the one with granny low as first, and the bellhousing as well if you want..will have to be picked up as it weighs ALOT!! have some other Yblock parts like exhaust manifolds, a two-barrel intake manifold..
    I need a three speed manual car bellhousing for a Yblock.. or any Y engine parts maybe..
  9. What engine do the covers fit ( y block ?? ) and whats the protocol with me being outside the usa? I have parts to offer up but I'll understand if I'm told to sit on my hands! :p
  10. Hooligan63
    Hooligan63
    Bump,would like to see the people that are getting stuff putting stuff back up,that's why it's paying it forward,which means you keep it going and p***ing a deal on to the next person.I still have the sheet metal up for grabs out here in Yucaipa,CA(So. Cal.,Inland Empire area).One sheet is a 4'x4' sheet of regular steel,and the other is a 3'x4' sheet of stainless steel,both sheets are 16 gauge.
  11. REM/Mo
    REM/Mo
    from Missouri
    What exh manifolds do you have. Need some for duals.
    Thanks REM
  12. chopper daddy
    chopper daddy
    I have a radiator from a newer Camaro. Got it at a swapmeet but don't need it. Looks to be in very good shape. Free for local pick up, or I could ship it if u pay shipping. It's big though. Also have a grill shell from a Farm-All tractor. Could work for a fenderless truck or just as a different grill shell. Same deal, free, and best to pick up - shipping may be pricey due to size. PM me and I'll send you pics.
  13. norton
    norton
    Is the dash still available?
  14. r8odecay
    r8odecay
    ya man, still got it.
  15. 48fordnut
    48fordnut
    you don't have to get something, just feels good to give something. i have a chop saw, works well, has a broken handle and sw, but it is hot wired, scares me but works fine. come get it.
  16. 6berry
    6berry
    i have all kinds of 1946-1948 and 1953-1954 Plymouth parts. I have all kinds of random things for them.
    I need anything for a 1948 Plymouth or anything hotrod
  17. Hooligan63
    Hooligan63
    Do you have anything for a '53 Plymouth Cranbrook?Looking for the door lock rotor for the drivers side door.I know,it's an odd piece to look for,right?
  18. patrick66
    patrick66
    Posting up a freebie - it's a complete axle ***embly for a '60 - '66 Chevy or GMC half-ton pickup. Came off a '66 C-10 with coils. Complete drum-to-drum, includes e-brake cables, too! I will not ship this puppy, whomever wants it, needs to come and get it. I'm hanging onto it until the end of June, then it goes to s****. I know it needs brakes and a pinion seal, as a minimum. It has 3.73 NON-Posi gears in it.
  19. DMFB
    DMFB
    I have some original suspension parts for a 40 chevy pickup including the axle. I'm looking for a different set up.
  20. norton
    norton
    Original 54 chevy fender skirts w/ hardware in good condition. One still has the rubber still on it. Pm me if you want them. Will post pictures later.
  21. CadDaddy42
    CadDaddy42
    Any chance you could ship it? Take it to a FedEx / Kinkos, give them my FedEx account number, and tell them to box it, ship it, and bill me :D
  22. Leadsled RnR
    Leadsled RnR
    from CO
    Bezels sent to Danimal today! Just got my new uprights on this past weekend, so I also have some stock 54 Chevy uprights and steering arms for you earlier chev guys who wanna lower a bit in front.
  23. 48fordnut
    48fordnut
    cad daddy, you are second in line. the other guy is getting bacck to me. Its pretty heavy.
  24. R.Allan
    R.Allan
    from Ca
    got a frame frame rails 2x4 z'd for an a project i sold. also front end of a 29 chevy axle etc. .
  25. norton
    norton
    Here's the pics but there already gone. I just shipped them to Leadsled RnR. Hope you like them.
  26. Hooligan63
    Hooligan63
    PM sent on the frame rails
  27. Leadsled RnR
    Leadsled RnR
    from CO
    Many thanx to Norton for the skirts! freakin fast shipping to!
  28. Double Caddy
    Double Caddy
    from virginia
    I really need a electric fuel pump. 6 psi I bought a carter 8 psi for a bbc mechanical but frame clearance wont allow for the fit. the carter was installed while the engine was on the stand . no fuel has been run thru it.if that doesnt work for anyone I also have a 52 caddy intake manifold thats in good shape.
  29. r8odecay
    r8odecay
    i'll take the caddy intake.
    Norton, i haven't forgotten about your model A panel. I'll get it in the mail tomorrow. i got the shipping...
    EDIT: The Model A panel is in the mail for Norton...CHEERS
  30. 48fordnut
    48fordnut
    Cad daddy gets the chop saw. will send it out in a couple of days. Hurt my back today. Hope you like it. any one have any pieces of garnish moulding for a 28/29 mod a coupe,or ft doors of a 2 dr? any will be better than none. thanks, jim.
