Pay it foward = free parts for HAMB members
Discussion in 'The Hokey Ass Message Board' started by axeman39, Mar 18, 2008.
  1. looking for any remains of the rear sides of a 30/31 5 window...something some one cut off for new or???is rusted and they found something bettrer????or??????? i have quite a few itms could go forward.........sbc nos oil pumps, good heads sbc valve covers M/T finned.......
    maybe we should remane this thread to
    Pay it/Swap it / forward............
  2. Fenders
    Fenders
    Desoto Power flite transmission from a 55 desoto, might fit 54 56 57 Plymouth Chrysler Dodge... Has the parking brake on theback... Going to the boneyard soon, if you can pick it up it's yours... Stow M***.
    See my sig. for want.... pix attached...
    PM direct, I don't watch this thread often.
  3. Double Caddy
    Double Caddy
    from virginia
    interested in the aircleaner Novatattoo
  4. lrs30
    lrs30
    from Kentucky
    I was notified that I am recieving SMALL CARB AND A SHORT TAIL SHAFT SECTION, So I need to pay it forward, does anybody need any of my stuff I got posted? Karma is a good thing I will look and see if I have some other stuff to help out the cause..Ryan
  5. Hackerbilt
    Hackerbilt
    Early Ford Dating Service....
    Hey...anyone have a lonely right side 48 Ford car style spinster...I mean SPINDLE with good bearing surface/threads????
    A bit sloppy in the main bushing is fine...you'd expect that after a life on the streets.:eek:
    Doesn't even have to have two eyes...one would be fine by me! :eek:
    "Lefty" and I could sure give her a good time....I mean HOME! :rolleyes:
    We'll treat her REAL good...I promise!!! :D
  6. lrs30
    lrs30
    from Kentucky
    BIG HUGE THANKS TO DOUBLE CADDY FOR THE CARB.. Now I just need to return the KARMA to SOMEone.. I have sent several things to guys in the past 54 chev Hinge Spring, Trans DATA PLATE FOR a 49 Ford TRUCK , Stainless trim for a 54 Chev, before this PAY IT FORWRD THREAD STARTED, I mean is'nt this what its all about is helping each other out, lets keep it up guys, and a huge thanks to DOUBLE CADDY you just made my day.... Ryan
  7. LUCKYMOODY
    LUCKYMOODY
    Irs 30
    I could use that model A window crank.
    I have a couple items I could part with as well;
    1955 Chrysler New yorker rear end (pick up only)
    331 hemi motor mounts from same car.
    Some stainless trim, Complete roof sheet metal and trunk lid.(same car-4 door)
  8. lrs30
    lrs30
    from Kentucky
    Sorry maybe I have that worded wrong, I need one don't have one to offer, sorry..I will check my post and edit it if its wrong,..Ryan
  9. LUCKYMOODY
    LUCKYMOODY
    My bad, should have read closer.I am going to a Model A swap this weekend, maybe I'll find two of them.
  10. Little Wing
    Little Wing
    from Northeast
    more to go ...Eelco Rader Single Rib 14x6 4 3/4 bolt pattern,,will need rechrome
    Looking for Ford Steering arm/hoop
    and a single ( 1/2 ) a wishbone ,,see above post
  11. Double Caddy
    Double Caddy
    from virginia
    Glad to have helped.
    Todd
  12. 30dodge
    30dodge
    from Pahrump nv
    3 speed manual ****** from a 63 Ford Econoline 6 cyl. I was told no problems.
    This is not real light but it is clean, pick up in Vegas or I will ship on your $.
    GONE
      89.7 KB
  13. lrs30
    lrs30
    from Kentucky
    HUGE THANKS to LOBUCROD For the 350 turbo short tailshaft section, now I just need to find a slip yoke for this thing and I am in business... Thanks Again Ryan
  14. axeman39
    axeman39
    from Saco Maine
    Can anyone tell me if this ****** will bolt up to a 57 392 hemi?
  15. poboyross
    poboyross
    from West TN
    I've got a running 1950 216 w/3 speed trans...all working. I took them out to put an SBC in my Chevy. It also has a new air filter *not pictured*. The carburetor needs a little work.
    What I'm looking for:
    -Nice 4bbl carburetor, automatic choke for my SBC
    -patch panels for the front floor, rockers, and rear quarters
    -driver's side door 49-52
  16. hipkatgreaser
    hipkatgreaser
    I've got a 650 holley with vac sec. and a q-jet with secoundary problemsthey bind a bit at first so it doesn't completly close
  17. poboyross
    poboyross
    from West TN
    Das motor is yours. We'll finish our dealin's on PM :)
  18. Saxon
    Saxon
    from MN
    2 - 1932/42 PU and Wagon 12volt tail lamps. - GONE
    Sacramento ford - 35-36/39pu Headlamp wiring and sockets.
    Holley fuel pressure regulator 4-9lbs 3 connections. - GONE
    Summit - fuel pressure guage. 1-15lbs. - GONE
    About 3ft of braided fuel line. -GONE
    53' ford trunk lock w/ keys.
    1 - ****s SBC oil cap - GONE
    Speedway 3 inch lower blocks - note*** these are wider then what could be used on my 53'. - GONE
    Bob Drake (new never installed) 46-48 radiator cover.
    I'll mail things out if anyone pm's me. Won't promise it'll be fast.
  19. LesIsMore
    LesIsMore
    from Ohio
    I could use the taillamps
    I'll come up with something to make available
  20. Saxon
    Saxon
    from MN
    Les PM'd you back.
  21. Dooley
    Dooley
    from Buffalo NY
    hipkatgreaser, I'll take the holley 650
  22. Road_Rat
    Road_Rat
    ill take the blocks if not spoken for..
  23. lrs30
    lrs30
    from Kentucky
    I have some cab corner patches for a 72 Chev GMC Pick-up left and right NEW NEWNEW if anybody needs them, may fit other years, pm me for details..
  24. i have a pair of ansen 3.5 x 15 aluminum slots (ya know the vintage g***er wheels) with new bias ply rubber on them from back in the day, the odd thing is the bolt pattern its small early mopar 5 lugs on 4 inch bolt circle. ive seen these go for a bunch on egay and wud be glad to trade them for a used msd 6al that works or ? whatcha got ? im hevy into desoto high deck hemis and got a ton of other ****, what do you need ? pm me . this is what hot rodding is all about great idea
  25. 6inarow
    6inarow
    I have a set of mostly complete rear brake stuff for 53-54 chevy: drums, cylinders, keepers, emergency cables - no shoes. This is sort of heavy, but send me and address and cover the shipping and its yours
    PM me - I dont check this thread enough
  26. hipkatgreaser
    hipkatgreaser
    Holley spoken for still have q-jet it is in workin order just needs a little help
    lookin for grill and misc. front and rear trim for a 64 belair 4 door
  27. Twicecustom
    Twicecustom
    I have a cowl for a 31? Chevy truck. Its allright shape with a little rust in the one corner. I'm In ND But have a truck going to Mpls next week. I can get anyone some pics tomorrow if they want.
  28. Double Caddy
    Double Caddy
    from virginia
    I have an older autopuse 12 VDC fuel pump and NOS brand fuel pump that I didnt end up using .
  29. ...doc...
    ...doc...
    from Houston
    I have a 53 Chevy 210 rear bumper, dent's and dings in it, and chrome is flaking off. Partial rear "push bar" goes with it.
    Local pick-up only, sorry
  30. Double Caddy
    Double Caddy
    from virginia
    found the picture of the NOS pump
