PB for the 59 Ranchero
Discussion in 'The Hokey Ass Message Board' started by Beep, Nov 9, 2009.
  1. :D Wow, I installed a power brake conversion set up on my 1959 Ranchero over the weekend. Holy sheeeet Batman, the thing stops on a dime now even with the old style drum brakes front and rear. My next move will be spot brakes on the front,,,thats "calper brakes" for you yunguns..
  2. Big Tony
    Big Tony
    Uptown...I've always been a fan of stopping when needed
  3. :) next comes the air shocks (got em), stronger sway bar (getting one), a trailer hitch (making one). Then PS is next. I have all the PS stuff, just gotta get it cleaned up, re-furbished and installed. Once it's all done, I'll use her to tow the GizzleHopper to tracks that are short distances away.
    Real nostalgia there my man
  4. Paul2748
    Paul2748
    What/whose set up did you use?
  5. hotrod-Linkin
    hotrod-Linkin
    granada spindles may bolt on with little problems.
  6. 55 dude
    55 dude
    what is the conversion box for ps.?
  7. weez
    weez
    I need a booster for my '58 Ranchero, even with LTD spindles and discs, my foot's working too hard. Any tips on the right booster? A local shop tried several boosters and said it worked better with none. Maybe I need to start over with matched components, but that's a lot of **** to buy!
  8. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I would stay away from air shocks... seriously. I bought brand new ones before my trip to texas and they're toast... maybe overload springs if its to help compensate load. I'm adding a panard bar for sure and replacing all the rear spring bushings. I had a lot of rear end sway and rubbing whitewalls...
    I have PS in mine... it rules.
  9. spinner
    spinner
    what booster/ master did you use? winter here time for some updating!
  10. shoprat
    shoprat
    from Orange, CA
    Try ABS in Orange Ca Make sure u have the Ford type prop valve also
  11. 55 dude
    55 dude
    TUCK is your ps factory or..? any pic's. thanks.
  12. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    yeah its factory-
    I don't have any pics off hand but next time I'm in the shop I'll snap some-
  13. abe lugo
    abe lugo
    Guys, if you run a later ford engine with Original PS and you use a late 5.0 power steering pump, you need to get one of those PS adjuster valves one of the rod shops out of R&C makes them. I have a 57 with a 351W but original PS and it's too fast.
    For PS there are about 3-4 ways to go about it.
    1. get an original setup,-- BTW I have an original Y-block pump and bracket if anyone needs that. but you need the power ram brackets for the idler arm and the pitman arm.
    2 605 style box, apparently this route has issues on the 57's that been converted.
    3 rack steering the old wurth kit, there are couple other guy making them apparently Rick has issues, I don't think he's even making these any more but it not rocket science to make your setup. Just look up 57 ford rack and pinion steering, 59's are very similar.
    4 mustang 2 your front clip, but there something wrong with that on this board!! hehe!
    BEEP, please post what company you get the better swaybar from. I have a Quickor suspension front one on my 64 wagon and will be installing the rear. It rules!
