Hot Rods PBM camshaft
Discussion in 'The Hokey Ass Message Board' started by chascue1, Feb 6, 2010.
  1. chascue1
    chascue1
    local engine builder here uses the PBM brand of camshaft......anyone had good luck with that cam......model #140-132 453 lift , 284 duration..... thanks, charlie........:confused:
  2. lippy
    lippy
    from Ks
    Never heard of them. Lippy
  3. man-a-fre
    man-a-fre
    Bet its an erson.
  4. v8 Bake
    v8 Bake
    dont know about their cams but their alum. heads are good.
  5. Kenneth S
    Kenneth S
    PBM ownes Erson Cams
  6. holeshot
    holeshot
    from Waxahachie
    CHARLIE...NO i havn't, and erson is an old builder. so your probably safe! i personal like COMP. because most drag racers use them, and they explain better than anyone on their specs...POP.
  7. Tedd
    Tedd
    As with any brand camshaft and especially a brand you're unfamiliar with, be sure to check the #6 cylinder as well as the #1 cylinder when degreeing it in. On all V8's, the #6 cylinder will share the same TDC so it's just a simple matter of moving the dial indicator from #1 to #6 during the degree in process and spend the extra four minutes or so in checking both lobes on #6 and verifying that they are within a couple of degrees of the numbers or values you obtained on #1.
