Technical pcv 235 engine
Discussion in 'The Hokey Ass Message Board' started by 68caddydaddy, Dec 6, 2015.
Tags:
  1. 68caddydaddy
    68caddydaddy
    Hi gearheads, I want to get rid of the road draft tube located at the bottom of the 235 engine. I read an article of someone who installed a modern pcv valve and hooked it up with some tubing to the vacuum connection located at the intake manifold . Can anyone tell me if this is a good system to ventilate the crank area ? You have to use a closed valve cover (no slits) and install a breather on it .
  2. gas pumper
    gas pumper
    What I did on my 235 was replace the vent tube with a breather ***embly/oil fill from a GMC 270-302. And than closed the valve cover vent and pull from the top of the valve cover into the intake where I put a PCV. It works and vents the engine as GMC designed.
    I got pictures on my phone but don't know how to get them to here.
  3. oj
    oj
    I left the draft tube but welded a plug into it and a bung (in the draft tube) where it wasn't obvious, a hose ran from the bung to the intake manifold with PCV valve inline. Works really good.
  4. flux capacitor
    flux capacitor
    Freeze plug' with hole for grommet. Flux
    volvobrynk likes this.
  5. rusty rocket
    rusty rocket
    Not a six popper but on my flathead I left the draft tube and installed a k /n style filter clamped on the end. Ive never had a problem with condensation or oil ****z coming out of the tube. Way easier then the pcv.
  6. bowtie56jw
    bowtie56jw
    see flux's pic above. its what ive been running this last summer. i used a dorman freeze plug number 555-024 drilled a 3/4 hole in it and used black rtv to glue a mr.gasket pcv grommet # 6379 into it, used a standard ignition v237 pcv valve. i bent up 3/8 steel line but you could use hose just as well. i drilled my carb spacer and used some jb weld to seal a 2 in piece of 5/16 tubing for a ****** to hook the pcv line up to. my car is a 57 chevy and it uses a vented oil cap.
    hope the info helps you
    flux capacitor and gimpyshotrods like this.
  7. gimpyshotrods
    gimpyshotrods
    ^^Do this.^^
    flux capacitor likes this.
  8. 68caddydaddy
    68caddydaddy
