PCV and brake booster
Discussion in 'The Hokey Ass Message Board' started by 57wes, Jul 22, 2024.
  1. 57wes
    57wes
    My 57 chevy has the 283 with the draft tube. I'm doing away with the draft tube and want to connect the pcv valve and brake booster to the rear of the original Rochester 4jet. My problem is connecting all this together. The port at the back of the carb is 1/2", the PCV hose is 1/2" and the brake booster is 3/8". Any design ideas or pics would be greatly appreciated.
    Thanks guys
  2. justpassinthru
    justpassinthru
    I wouldn't connect the PCV and brake booster to the same vacuum port.
    A PCV is kinda like a controlled vacuum leak, which will affect available vacuum to the booster if tied together.
    Kinda like hooking up an electric choke to the + side of the ignition coil. Doing that can affect current available to the coil.
    Need to find a separate vacuum source.
    Bill
  3. jimmy six
    jimmy six
    Spacer under the carb with fitting on the front. Mixes better with blowby…
    Johnny Gee likes this.
