Hot Rods PCV brings my Hemi up to 1960’s technology!
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Dec 10, 2025 at 10:40 AM.
  1. flynbrian48
    flynbrian48
    I put a PCV valve in the valley pan of the DeSoto Hemi in the roadster with bits from Hot Heads Hemi parts. Cheap, easy, and the car no longer smells like crankcase fumes!
  2. BJR
    BJR
    Is that a goose?
    jimmy six likes this.
  3. jimmy six
    jimmy six
    Yep..a good idea for sure.
  4. flynbrian48
    flynbrian48
    A pelican. It had fishing line around its beak and had been unable to eat. We took it to a seabird rescue place here on Longboat Key. My good deed for the day.
    SS327, cfmvw, Blue One and 9 others like this.
  5. flynbrian48
    flynbrian48
    It seems to run better too. Before I had to keep the choke closed when cold, now it doesn’t stumble and cough until it warms up. Bonus.
    Tow Truck Tom likes this.
  6. “A wonderful bird is the Pelican.
    His beak can hold more than his belly can.
    He can hold in his beak
    Enough food for a week!
    But I'll be darned if I know how the hellican?”
  7. BJR
    BJR
    Nice to see people helping animals caught up in our garbage.
    SS327, cfmvw, down-the-road and 2 others like this.
  8. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Congrats on the PCV best thing ever for engines.
    Growing up was getting difficult 'til motors were made to stop feeding my lungs with oil fume.
    My childhood was largely in a gas station, on a busy street, with a considerably steep hill.
    The air became sweeter as the older cars went out of service.
    down-the-road and jimmy six like this.
  9. AldeanFan
    AldeanFan
    PCV is a great upgrade,
    I added one to my Yblock same a you did and it’s a great improvement.
  10. 1935ply
    1935ply
    from peyton,co
    I have a pcv valve on my flathead and my dodge hemi, they are a great addition. Is that hose in the second picture traditional?
  11. willys36
    willys36
    This is where I put the PCV valve in my Mysterion reproduction, in a drilled tapped hole in an intake runner on the underside of the '60s vintage Edelbrock F380 tripower manifold. It is covered by a sheet steel baffle plate. Wanted the engine to run but didn't want a draft tube or PCV valve hanging on the outside. Seems to work ok, for show car anyway.
    This is where I put it on my 331 hemi. I made my own 'racy' valley cover from a piece of 1/4" aluminum. PCV adaptor is a 1/2" rigid conduit bulkhead fitting that fits in a panel hole held by a big jamb nut. It has pipe threads for hose fitting on top to accept the PCV. I stuffed it with some co**** stainless steel 'wool' from a kitchen scruntchie to limit oil blowby, held in with a big cotter key.
    flynbrian48 likes this.
  12. Adriatic Machine
    Adriatic Machine
    Good call. I put one in my 223 I-6. The draft tube hole is conveniently located under the rear of the intake manifold and the oil cap is on the front of the valve cover so the vapors get nicely ventilated right through the engine.
  13. George
    George
    I put a short bolt in the hole where the long puke tube bolt screwed in, just stuck a grommet in where the puke tube was & inserted a PVC valve. One run to the parts house & a bolt out of the bolt bucket.
  14. 51504bat
    51504bat
    Best thing I ever did for the 8ba in Rusty (other than the Bubba Chevy distributor conversion)
  15. jimmy six
    jimmy six
    In the 60’s when the first used the valve was a screw in usually at the back of the carb. All were serviceable also. I found one for 56 Y-block and put I between the dual quads I am currently using. The tube goes to the valley cover device from a 64 pick-up truck that had to be modified to miss the intake. A V-100 is what’s available today but it is sealed IMG_3656.jpeg IMG_3640.jpeg
  16. Blue One
    Blue One
    from Alberta
    Was the pelican hard to catch Brian ?
    Sometimes animals realize they need help.
    I see your location mentioned as Sarasota Florida.
    Have you abandoned frozen Michigan for good or just while it’s frozen ? :D
    Florida definitely looks like better roadster weather than Michigan at least right now.
  17. milwscruffy
    milwscruffy
    He's a snowbird now for the winters.
    Blue One likes this.
  18. flynbrian48
    flynbrian48
    We go back to our home in Michigan in early May and leave the end of October. That gives us the great November, December and January here, and we miss the (increasingly) hot summer in Florida. We absolutely LOVE Sarasota.
    The bird was not thrilled about being picked up and carried, I put a beach towel over its head for the 20 minute drive in the car. I think it was exhausted, dehydrated and malnourished from its ordeal.
