Technical PCV in a banger
Discussion in 'Traditional Hot Rods' started by Ron Brown, Apr 10, 2018.
  1. Ron Brown
    Ron Brown
    has anyone installed a pvc valve in a banger...if so, any tips?
  2. denis4x4
    denis4x4
    from Colorado
    Do a search over on the Fordbarn...several threads on the subject there
  3. Ron Brown
    Ron Brown
    I did but couldn’t find anything....I will try again
  4. 5280A2
    5280A2
    Get a copy of Jim Brierly's book; he has a whole chapter devoted to building a PCV system for an A or B. Any four cylinder enthusiast should own his book as it is both entertaining and full of great tech.
  5. ejgloss
    ejgloss
  6. Model A Gomez
    Model A Gomez
    Interesting, I have two bangers and a PCV would help keep moisture out of the engine and cut down on sludge. I'm not running vacuum wipers and could use the port on the intake as the vacuum source.
  7. boo
    boo
    from stuart,fl.
    have been running a pcv on my A for years. also on 8ba, they both had leaks at front and rear mains. on A ran from tap into side cover then into intake manifold, sealed the vent @ oil filler, no leaks for 15+- yrs. same basic setup on the V-8. 1974 a man who drove a mdl A back and forth from ca. to fl. told me that this is how he stopped leaks, works for me.
