Technical PCV in SMALL BLOCK CHEVY
Discussion in 'The Hokey Ass Message Board' started by nunattax, Jun 10, 2020.
  1. nunattax
    nunattax
    does it matter where in the valve cover it goes .i can fit drivers side front or passenger side near the back.with a breather on the opposite corner.
    67L36Driver likes this.
  2. squirrel
    doesn't really matter too much. Make sure the hole has a good oil separator type baffle under it.
    nunattax likes this.
  3. nunattax
    nunattax
    no oil seperator baffle in the covers at the moment thanx
  4. Dooley
    Dooley
    from Buffalo NY
    pcv will suck oil without a baffle
  5. ..........They make rubber grommets that have a little offset slot that acts as a bit of a baffle.
    67L36Driver and scrap metal 48 like this.
  6. gimpyshotrods
    gimpyshotrods
    There are baffled grommets. They work fine.
    scrap metal 48 likes this.
  7. Man did I see a neat idea not to long ago.
    Few birds caught.
    Boxed frame, custom valve cover adornments that Each had a hose to each side of the frame.
    As the car went down the road each frame rail was a road draft tube and each frame rail was coated internally with corrosion protection.
    Worked really well, great execution aesthetics as well.
  8. 67L36Driver
    67L36Driver
    Diagonal ventilation across the engine is preferred, valve cover to valve cover.
    [emoji108]
    unkledaddy and nunattax like this.
  9. nunattax
    nunattax
    valve covers are finned chevy alloy .cant remember what they like underneath.at the moment there is a mist from the k +n breather. pvc to the air cleaner fitting is dry.(pvc is new ,k+n filter is recent new)
  10. nunattax
    nunattax
    [​IMG]ordering a pair of these from summit # mor-68772 . 3/4 internal bore .thanx for the info never knew of them til yesterday
  11. .........That's them. Those are the ones I mentioned above, just couldn't remember where I got them from. Guess they are a Moroso part.:)
  12. On my SBC (OT car) I take fresh air from the air cleaner to the front of the driver's side valve cover. PCV valve in the back of the passenger's side valve cover to a catch can and then to the intake. I've used this setup for about 2 years, and it seems to work really good.
    Same setup on a buddy's blown alcohol altered, with the addition of a catch can in the back of the cage. I guess cutting and welding in the cage wouldn't be a very pleasant job. :)
  13. nunattax
    nunattax
    these look like they will work
    lothiandon1940 likes this.
  14. ..........They've worked for me.:)
    nunattax and scrap metal 48 like this.
  15. scrap metal 48
    scrap metal 48
    Worked for me ^^^ too...
    lothiandon1940 and nunattax like this.
