Technical PCV valve in Valve Covers
Discussion in 'The Hokey Ass Message Board' started by blowby, Jun 11, 2022.
  1. blowby
    blowby
    from Nicasio Ca
    Bought some M/T covers at the swap for my SBC. Already has the hole for a PCV valve knocked out and a grommet in place. Do I need a baffle plate screwed in under the valve?
  2. squirrel
  3. rockable
    rockable
    Everyone needs to understand that there is a ****storm of oil underneath the valve covers. Without good baffling, your PCV valve will **** oil into the intake of you engine and you will consume oil at a high rate.
    Also, NEVER install a brake booster check valve in place of a proper PCV valve. You will not believe the oil consumption. A friend bought a truck with a 289 SBF in it and it took several of us to finally figure out the problem.
  4. I have done it, thinking back I am not sure if there was a baffle or not?
    Blues4U and blowby like this.
  5. blowby
    blowby
    from Nicasio Ca
    I see they sell a grommet with a baffle built in. Good?
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    Only takes a little time to form a baffle of thin aluminum & JB Weld it in place .
  7. squirrel
    I takes a bit more work to get an original baffle out of an old stock valve cover, make it fit, and jbweld it in place.
  8. pprather
    pprather
    Just be careful that your homemade baffle doesn't interfere with the nearby, rockers arm in motion.
  9. THAT! is what I used on my 54! Yes, good
    lothiandon1940 and blowby like this.
  10. blowby
    blowby
    from Nicasio Ca
    There's already hole bosses for a baffle plate. These aren't mine, off the 'net, I'm not at home. IIRC the stock baffle goes in between two cylinders, I don't think it will fit where the M/T holes are.
    mad mikey and squirrel like this.
  11. 1971BB427
    1971BB427
    from Oregon
    I'm using one of those baffled grommets on my SBC and they work excellent. Just a slit to allow air, but doesn't **** oil.
    mad mikey, lothiandon1940 and blowby like this.
  12. gimpyshotrods
    gimpyshotrods
    I am a fan of the baffled grommet.
  13. blowby
    blowby
    from Nicasio Ca
    Did you guys leave that piece of foam in and push the PVC valve down on it or remove it? See pic above.
  14. Man, that was 20 years ago even tho it happened in HAMB time which seems like yesterday!? Pretty sure I pulled the foam?
  15. gimpyshotrods
    gimpyshotrods
    I have used Mr. Gasket and Moroso ones. Neither have foam
    I am certain that if it comes with foam in it, it needs to be there.
    lothiandon1940 likes this.
  16. The one I had with foam was designed to be run as is and there is a rubber baffle with a slot in the side to keep oil in. If you remove the foam is simply served as a rubber grommet.
  17. squirrel
    Perhaps the foam is a design change, to try to make them work? :)
  18. Naw, just a cheap Mr Gasket part we had in stock that I made work. 70s/80s blister pack parts
  19. 57JoeFoMoPar
    57JoeFoMoPar
    I used the baffled grommet with the foam, so far so good. I wanted to go the opposite of what you're doing; run smooth valve covers. I drilled the intake and stuck the PCV underneath the distributor, and picked up the manifold vacuum from the backside of the rear carb. You don't even notice it back there. Oil fill is though the tube in front. IMG_5752.jpg IMG_5753.jpg IMG_5801.jpg
  20. gimpyshotrods
    gimpyshotrods
    I have done a bunch like this.
    As you point out, it just disappears back there.
    fauj and 57JoeFoMoPar like this.
  21. 1971BB427
    1971BB427
    from Oregon
    The one I bought is a Moroso and it didn't have the foam inside.
  22. blowby
    blowby
    from Nicasio Ca
    This one has the rubber baffle as well as the foam. I took the foam out, the valve was smashing it flat.
  23. Dooley
    Dooley
    from Buffalo NY
    Screenshot_20220620-155657_Chrome.jpg The issue with the MT one's is that the hole is right above the rocker arm.
    The 2 holes next to the punch outs are what the baffle screws to
    This is what comes with them when you buy them new. Wouldn't be hard to make..
    deathrowdave, Just Gary and pprather like this.
  24. loveoftiki
    loveoftiki
    from Livonia,Mi
    I’ve used some aluminum flashing from Home Depot, bent it how I needed it, and tig’d them on the VC
    Tman likes this.
  25. bobss396
    bobss396
    Mr. Gasket makes a simple baffle, comes 1 per package. I just picked one up for my car. But simple enough to make.
  26. loveoftiki
    loveoftiki
    from Livonia,Mi
    Ok, when you guys screw your baffles in are you adding red lock tight? I always have this fear of a screw coming loose for some reason
  27. Dooley
    Dooley
    from Buffalo NY
    I did for sure.. same reason
  28. bobss396
    bobss396
    The Mr.Gasket one I picked up comes with lock nuts, but will loc-***e them anyway. If the bolts are not SS, I will replace them.
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    Thats why I made my own & epoxied them in , no fear of loose fasteners bouncing about !
  30. Just.dale
    Just.dale
    Hello all, what do you think about this setup for my pcv? SBC in a 36 Ford. Chevy script valve cover and I’ll run an inline pcv to the carb, intake air will be through the fill tube in the intake. This will be on the drivers side as it it has more clearance to the firewall. Let me know your thoughts, thanks, Dale
