Hot Rods Pcv valve placement.
Discussion in 'The Hokey Ass Message Board' started by D-man313, Mar 18, 2016.
  1. D-man313
    D-man313
    Before anyone goes on a rant and says use the search bar, I did. So if there's a thread that answers my question, my mistake.
    My question is, I have a vacuum port on my intake behind the carb. Is this vacuum port just in an intake runner or does it go all the way to the valley to be sufficient place for a pcv valve. What about the port on the back of the carb? Or would I have to drill the intake down by the distributor somewhere in the last pic. Motor is a small block 350. Here's some pics.
    Thanks
  2. Dooley
    Dooley
    from Buffalo NY
    I'm pretty sure you need to access the area near the dizzy. you need crankcase g***es not runner air
  3. Habitual
    Habitual
    Both ports you are showing is a vacuum port. I usually plug into the carb for the PCV since what it is doing is pulling out Crank Case g***es. That is what the PCV is for. When the engine is running it builds pressure in the crank case and at higher RPMs it builds more. I have ran numerous cars with out PCV installed just valve cover breathers and at high RPMs blew them off...lol.
    Sent from my SM-T310 using H.A.M.B. mobile app
    pecker head likes this.
  4. scrap metal 48
    scrap metal 48
    The pis you show are for the PCV hose(one end).. The PCV itself can go to the valve cover or you can drill a hole in the intake(that goes to the valley).. If the latter is chosen, make sure to use a grommet that doesn't allow oil to enter, just fumes...
  5. 3banjos
    3banjos
    from NZ
    Looks like booster is running to carb base. I'd use the port shown for that, and run pcv hose to carb port.
    Some longer carb studs wouldn't go amiss.
    T.L. and choppedtudor like this.
  6. are you wanting to run old valve covers with no holes? if you mount the pcv in the intake make sure to fab up a baffle or you will **** a lot of oil. i've seen guys drill into the block behind the intake also.
  7. D-man313
    D-man313
    Yes Scotty. Trying not to pull the intake to drill one hole lol
  8. Blues4U
    Blues4U
    from So Cal
    Your question is confusing. From your OP I thought you were looking for a vacuum source to run a hose to from the pcv valve mounted in a valve cover. But after reading the replies it looks like your looking for a place on the intake manifold to place the pcv valve where it will reach the valley. Well if that port you asked about is pulling vacuum, then it would not be a source of crankcase pressure now would it?
  9. D-man313
    D-man313
    Thats what i am trying to verify. Looks like i will have to drill my valve covers. I really dont want to pull my intake off.
  10. Habitual
    Habitual
    The pic of the br*** fitting will be a vacuum port and so is the hose at the base of the carb. I miss understood what you asking.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    For about $25 with free shipping you can order brand new valve covers already with the holes from Amazon. And while you're at it, order new vac hoses for the booster and pcv, and longer studs to accommodate your carb spacer. The nuts look like they're catching half a thread. 8^)
    Jack E/NJ
    T.L. likes this.
  12. I have early vet valve covers. I didn't want to drill them. After doing some repairs on my Silverado. I found out gm went to a fixed oriface pcv on the 5.7. It has a
    .10 hole in it. So it got me thinking. I ended up drilling a .10 hole in my manifold under the carb into the vally.
  13. Blues4U
    Blues4U
    from So Cal
    PCV valves will close in the case of a back fire, preventing the flame from reaching the crankcase gases which can be volatile, especially if there is any fuel dilution of the oil. Your method doesn't offer that.
  14. Possibly. That was the intention of the original design. But gm didn't seem concerned about it with the new design. The service guide said the new design was fixed and would reduce oil consumption and improve ventilation. My truck seems to like it. My 36 runs like a champ. I really don't think there is much of a risk with a back fire. Plus I like to live on the edge alittle.
  15. Dan Hay
    Dan Hay
    I drilled a hole in front of the dizzy on an Edelbrock rpm for a SBC. I too didn't want to deflower my finned Corvette valve covers. I used a valve cover grommet in the hole and also JB welded a thin baffle below it. (an old HAMB alliance tag actually) The hose runs to the front of the carb. The fill tube in the intake acts as an intake.
    caseywheels likes this.
  16. blowby
    blowby
    from Nicasio Ca
    Ah, the old Hokey *** Manifold Baffle trick. :)
    lothiandon1940, Blues4U and Dan Hay like this.
  17. D-man313
    D-man313
    Well, I really didnt want to pull the intake, so i bit the bullet and drilled a valve cover. Put the pcv in the back side facing the firewall. I notice it's there but hopefully it blends in. Forgot to take any pics, so if anyone really wants to see it, ill take some this weekend when the trucks down from the lift.
  18. pics or it didn't happen
  19. D-man313
    D-man313
    Maybe if you'd stop by more than once a year.
    I'll take and post some pics probably this weekend.
  20. D-man313
    D-man313
    Here's some pictures.
    Blues4U likes this.
  21. DDDenny
    scotty t likes this.
  22. Blues4U
    Blues4U
    from So Cal
    Nice resolution, I like it!
  23. D-man313
    D-man313
    I thought about the baffles. I tried to keep it up as high as I could. I can always add one later on if I need to. I'm going to run it a little and see how it does
  24. looks good! i like the "chevrolet" scipt valve covers
  25. D-man313
    D-man313
    That's why I didn't want to drill the tops.
