Technical Pcv valves
Discussion in 'The Hokey Ass Message Board' started by Ponchoguy65, Aug 8, 2018.
  1. Ponchoguy65
    Ponchoguy65
    from Midland,TX
    Does anyone have the Delco part number for pcv valve on a Goodwrench crate? Gm doesn't list a specific number for the crate pcv. I put a fram on there when I put the engine in the car but at idle it rattles like a Chinese sewing machine opening and closing very fast, so I'm guessing it's the wrong weight spring in the valve as it should be closed under full manifold vacuum at idle? Also I'd like to get a 90 degree one this one is kinda funky pointing upright from the valve cover. Thanks!
  2. KJSR
    KJSR
    from Utah
    ACDELCO CV774C {#06487779, 6487779} GM Original Equipment
    Not sure what comes on the "crate" engine but this is the one I use
    lothiandon1940 likes this.
  3. Ponchoguy65
    Ponchoguy65
    from Midland,TX
    Okay I'll pick one up right now! Thanks for the reply. What size pcv hole is your valve cover?
  4. KJSR
    KJSR
    from Utah
    I have no idea. I usually get a grommet when I get a valve...fit check at the store.
  5. Ponchoguy65
    Ponchoguy65
    from Midland,TX
    Will do thanks again
  6. KJSR
    KJSR
    from Utah
    No problem!
  7. bobss396
    bobss396
    I got mine at Summit, made sure it fit my grommet first, just a regular AC Delco for a '74 Chevy 350.
    Ponchoguy65 likes this.
  8. Ponchoguy65
    Ponchoguy65
    from Midland,TX
    Is it a different part number than KJSR provided? That one says it fits a 1974 small block so I hope it'll fit my grommet if not I'll have to get the correct one
  9. KJSR
    KJSR
    from Utah
    That one fits 74-97
  10. bobss396
    bobss396
    I took my PCV valve with me when I was shopping for the valve cover grommet, local Pep Boys has speed shop of sorts inside it... the plus is that I don't have to talk to a counter person.
