Projects "Pea Green" the '29 Tudor build
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Sep 14, 2014.
  1. bjinx
    bjinx
    Front motor mounts
  2. Leon Sandcastle
    Leon Sandcastle
    Nah! I bet it's a cup holder:D
  3. '52 F-3
    '52 F-3
    from Central PA
    I should start putting something in for size reference on these "what this going to be?" posts.....
    put in a couple hours this evening on the bandsaw & drillpress; small update picture.
    340HilbornDuster and Hotrodmyk like this.
  4. '52 F-3
    '52 F-3
    from Central PA
    "water pump raise thing" (copy right pending), is just about complete, final sanding and some engine color paint. I'm trying to find some gloss dark brown spray can hi-temp paint, anyone have a source?
    also progress on engine mount....... put a 5 degree angle in to match engine to frame.
    ROCKER77 likes this.
  5. '52 F-3
    '52 F-3
    from Central PA
    made a few little changes to above picture and dropped of at "Gusset Welding" in Middletown, PA
    got the body on to test/place engine so when mounts welded up I can bolt in and start on steering/exhaust etc.....
    I'm super happy with how it fits; 1/2" between distributor and firewall, 1/2" between crank pulley and front spring U-bolts, 1/2" clearance all around 17 1/2" fan and 1/2" between fan and radiator (i'd like to have alittle bit more, but gonna go with it, engine will be very rigid mounted) and have about 2" minimum above carbs for some custom air cleaner/s.
    crank is inline with manual crank handle hole with a 6 degree downangle, only thing i'm not really happy with is auto-****** pan is very visible front side view. (not too self, don't leave painted orange)
  6. ROCKER77
    ROCKER77
    looking good!!
  7. You just keep impressing us, thanks!
  8. Hotrodmyk
    Hotrodmyk
  9. 340HilbornDuster
    340HilbornDuster
    Awesome................!
  10. '52 F-3
    '52 F-3
    from Central PA
    got the front engine mount welded up (10 separate pieces) and sanded to 100 grit, next is frame mounts...
  11. '52 F-3
    '52 F-3
    from Central PA
    time for another; guess was this is going to be?
    sanding disc is 12".......
  12. Leon Sandcastle
    Leon Sandcastle
    Steering component of some sort?
  13. 340HilbornDuster
    340HilbornDuster
    Seat rest brackets....?
    Rear bumperettes.....?
  14. ROCKER77
    ROCKER77
    custom framing hammer head???
  15. '52 F-3
    '52 F-3
    from Central PA
    all very close, (except "framing hammer"...... very funny) it's a front track bar mount (frame end)....
    also got this 1956 Delco-Remy distributor with a Pertronix ignition already to go off Craigslist.
    waynos likes this.
  16. kidcampbell71
    kidcampbell71
    Nice ! I love it, of course. Michelangelo of Pea Green baby. Artist at work.
    '52 F-3 likes this.
  17. 340HilbornDuster
    340HilbornDuster
    The "Renecance Rod"
    That mount is killer Dude...very organic.
  18. '52 F-3
    '52 F-3
    from Central PA
    getting ready to start on the steering column, shafts and joints.... seems like I'll have enough room with this exhaust manifold I'm thinking about going with.
    tacked the track bar mount.
    also picked up these 1" valve cover spacer at Spring Carlisle, still undecided on valve covers, but kind like to look of old steel ones.
  19. '52 F-3
    '52 F-3
    from Central PA
    no real updates, been busy with life......
    I've moved that damn steering box 3 times, tried 3 different exhaust manifolds and am still not happy.
    I'm considering cutting and welding a factory exhaust manifold to gain another 3/8", will see.
  20. kidcampbell71
    kidcampbell71
    A Belond style tri y header build would be fun ... did I say that ? I'll just slink away now. No trouble here ! Have fun.
  21. 1-SHOT
    1-SHOT
    from Denton
    you can try a early Chevelle exhaust manifold ,they dump at the Bach and clear the steering box on 40 Fords like they were made for it. I think Dorman products sells reppop ,They tuck in tight and have a curve in them where the steering shaft clears. It's just a thought and my 2ct. worth. Frank
  22. 340HilbornDuster
    340HilbornDuster
    Think paisley curves.....run with it...
  23. kidcampbell71
    kidcampbell71
    Hey five-two-eff-three. Just wanted to look at some cool pictures again. Hope all is well sir.
  24. ROCKER77
    ROCKER77
    Been awhile since we got an update. Needing my Pea Green fix!!
    Hotrodmyk likes this.
  25. Hotrodmyk
    Hotrodmyk
    ^^^^^what he said
  26. kidcampbell71
    kidcampbell71
    Glad I'm not the only one strung out ... all skinny, and shaking .... with the thousand yard stare scratching myself, and slobberin' on my bib. :)
    Hotrodmyk and ROCKER77 like this.
  27. Leon Sandcastle
    Leon Sandcastle
    I wanna see some new pictures and know what's going on with the project.
    kidcampbell71 likes this.
  28. '52 F-3
    '52 F-3
    from Central PA
    all is well in Pea Green'ville, just got busy over the summer with other stuff.
    Still am, but gonna try to start back whittling away at the exhaust and steering.
  29. dirt t
    dirt t
    A point of interest , on your distributor If you can pick up the latest issue of Hot Rod magazine October 2015
    page 106. I only have two fingers that know how to type or I would try to explain.
    Terry
    '52 F-3 likes this.
