Pearl/ivory paints
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Mar 15, 2012.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    So I want to do the lid on my car in a pearl like paint. Right now I am looking for suggestions on which route to take as far as types of paint, and color options. I've noticed a few new cars have a pearl/ivory paint as an option such as Cadillac and I believe Toyota. Its always cheaper to get a jobber paint right?
    any advice or tips would be greatly appreciated. Obviously I'm no pro painter, but I'm getting real good at sanding runs:D
  2. Mr48chev
    I don't know about cheaper but it would make it a lot simpler for someone to match the paint later if you used a factory pack color. Some late model Fords have a similar color.
    In 1982 When my wife and I picked the color for the 48 we drove by car lots during the day and then after dark to find a color that looked great both in the daylight and under the lights.
    They rolled a 2012 Chevy Volt into the airport terminal where I work today for show and tell that has a Crimson (serious candy apple) red on it that would have taken a world cl*** custom painter to lay on 30 years ago and now it's a regular base coat clear coat paint job.
  3. EDPACECAR
    EDPACECAR
    Had a friend tell me he just priced a gallon of a new Cadillac Blue/Pearl. Over $800 a gallon.
    Plus that doesn't include clear etc.
  4. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Spies Hecker has converted the G.M. Diamond White Pearl to a Two Stage Formula.
    That would be the least expensive way to shoot a White Pearl. They may have also converted the other White Pearls from other manufacturers. The Lexus White Pearl is
    also a really nice White Pearl. Keystone / LK&Q Corp. used to handle Spies Paint.
    Try out your local Keystone branch. Here is a web link : http://www.lkqcorp.com/
    Good Luck,
    VR&C.
  5. SinisterCustom
    SinisterCustom
    HOK Snowhite (PBC44)......it's a pearl white that's a little "dirty"...like Ivory.... and it rules.....
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    I think I could get away with a quart of paint to do the whole lid. Thats a quart of each layer. I checked on the Caddy color a few years back and at the time it was $300 a quart, I was blown away.
  7. hillbilly4008
    hillbilly4008
    from Rome NY
    I just checked TCP Global site for this. Price is pretty good at $87 a quart.
    http://www.tcpglobal.com/hokpaint/hok-shimrin-designer-pearls.aspx
    I'm not to keen on the color sample online, I wish I could see it in person.
  8. BISHOP
    BISHOP
    That is a beautiful color, looks like pure money. I would use it.
  9. SinisterCustom
    SinisterCustom
    You could always order a little from coastairbrush.com to paint a small part with...they package it in small quanities...:) http://coastairbrush.com/products.asp?cat=49
    My T coupe is going to be Snowhite.....:D
  10. hillbilly4008
    hillbilly4008
    from Rome NY
    We share the same Keystone branch, and guess what! they sell HoK paints!
  11. hillbilly4008
    hillbilly4008
    from Rome NY
    ooh, $10 cheaper too!
  12. chopolds
    chopolds
    from howell, nj
    I priced out paint for a 66 GTO years back, in a factory Caddy Candy red color. I was shocked at the price, so I checked it out in HOK REAL Candy Apple Red, and it was hundreds cheaper than Dupont Chromabase. And it looks a hell of a lot better. Quality is top notch, so you don't have to worry about touching it up later, at least color-wise...it is still difficult to get perfect with any 3 stage.
  13. Hellfish
    Hellfish
    My wife found the perfect red for the roof of her '51. It was a Jag color and crazy expensive. After a little digging she discovered that it cross-referenced to a Toyota color that was a LOT cheaper.
  14. Abomb
    Abomb
    My wife's 2011 HHR has that same color, it's called "crystal red metallic tintcoat" My guess is that it's a 3 stage color, but it is definately a beautiful candy like red.
  15. Flathead Johnny
    Flathead Johnny
    from MA
    i have been looking at pearl oranges to put on my 56 F100, TCP Global seems to have the best price and either House of Kolor or PPG have a good selection of pearl in a reasonable price, if you are going to paint yourself practice and walk the panels, it will be my first time spraying pearl myself and I have been researching technique and errors to avoid
  16. BISHOP
    BISHOP
    Low pressure is the key. Dont lay it on wet....apply a couple dry coats to finish up the job.
  17. SinisterCustom
    SinisterCustom
    Know what's *****in' for orange??? A Vitamin C metallic with gold pearl in the clear......Popciclicious......
  18. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    I'm not keen on H.O.K. It is really finicky stuff. Spies Hecker is good stuff. If you can get the Three Stage converted to a Two Stage, you'll save $$$$$$.
    VR&C.
  19. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    HOK Is AWESOME! I sprayed the top of a chevy truck with it. Looked so good and no harder to spray than anything else. 000_0615.jpg
