Technical Pedals-Firewall vs floor
Discussion in 'The Hokey Ass Message Board' started by Stu, Dec 4, 2023.
  1. Ned Ludd
    Ned Ludd
    I asked a related question about six months earlier: https://www.jalopyjournal.com/forum/threads/earliest-hanging-pedals.1294665/
    Conceptually, pedestal pedals are purer to me for a ladder-frame car, especially an earlier one whose overall shape is a lot about the frame. But I get the packaging issues. Pedals with offset arms and concentric shafts might be something to work with. They can even be detailed that the floor penetration is locally perpendicular to the shafts.
  2. 05snopro440
    05snopro440
    Lol okay? What a thing to try to correct. I've had mine across the scales a few times, it is 3,800 lbs.
    Brochure curb weight vs a non-stock 62-year-old car.
    Bandit Billy likes this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    My '65 impala weighed in at 3400 which why your weight sounded heavy,so I looked it up ! That's all , nothing nefarious .
    05snopro440 likes this.
  4. Bandit Billy
    Bandit Billy
    Are you a large man? :cool:
  5. Bandit Billy
    Bandit Billy
    Like someone mentioned here, the brake booster M/C ***embly needs to be braced if hanging them from the firewall.
    This is after the prep
    This is before. I welded steel reinforcing to make the firewall mount...
    and added a steel U channel support brace from the pedal ***embly to the dash. It bolts on using the column drop bolts and studs I added to the top of the pedal drop. The other arm is my brake light switch. It makes for a very rigid mount and stiffened the dash/column at the same time.
    Chucky likes this.
  6. 05snopro440
    05snopro440
    Lol. That's without me in the car. Full of fluids, spare tire, etc. It lived on a farm for several years, maybe there's dirt hiding in it.
  7. 05snopro440
    05snopro440
    That looks good. It's very similar to how a lot of modern factory vehicles are done.
  8. Bandit Billy
    Bandit Billy
    Sorry, couldn't resist. :cool: Maybe someone stashed some gold in the rear quarters. I pulled the front end off a T/A a few years back and someone had cut a "door" in the drivers side cowl. Definitely a smugglers mule car. Nothing in there though.
  9. Bandit Billy
    Bandit Billy
    I have built a lot of F body GM stuff and I just used the same parts and the same tech. It worked for them. And it is easy to source parts.
  10. 1971BB427
    1971BB427
    from Oregon
    My personal preference is firewall mounted. Yes, you can see it and they're usually not pretty. But I like the fact it's easy to access to check, or add fluid, and not worry about getting fluid on my carpet, or having slotted openings for pedal travel.
    I backed my firewall with 1/4" plate, and also a brace from the pedal bracket to the dash for strength.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    No slot in the floor with this type pedal . How often do you check your brake fluid ??
