1952-59 Ford Peep Mirrors
Discussion in 'Off Topic Hot Rods & Customs' started by mcclellandb, Aug 4, 2015.
  1. mcclellandb
    mcclellandb
    Is anybody using 3 or 4 inch peep mirrors? Pictures of how they look would be appreciated. Thanks.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    You'll see them on a few Google images,more common on 1946-54 Fords than after 1955.
  3. I'm a fan of them
  4. Dos Cincos
    Dos Cincos
    I'm running them on mine as well. Same placement as Chris ^^^
  5. EchoOfGecko
    EchoOfGecko
    I've got one... make sure to mount it far enough forward, probably right at the lead edge of the window would be good. Mine was mounted by the previous owner of my car and was mounted a little too far back to be very useful, and the paint is damaged underneath it, so it'd be hard to move. Looks cool, though. :)
    welderdave562 likes this.
  6. 57Custom300
    57Custom300
    from Arizona
    I have one on my 57 mounted as close to the front edge of the door frame as it would go. Works fine. Like having no antenna on mine I can't see drilling holes in it.
  7. welderdave562
    welderdave562
    This is out of subject but I was wondering if you had a close up picture of your spot lights. I am trying to figure out a good spot for mine. On the Victoria's it has the stainless molding all the way up the pillar
  8. EchoOfGecko
    EchoOfGecko
    This is probably the closest one I have. I'm in a different city than my car at the moment, but once I get back I can try and get a closer pic if I remember.
  9. mcclellandb
    mcclellandb
    Are those 3" or 4"?
  10. welderdave562
    welderdave562
    Thanks i appreciate it. Did you drill all the way threw pilers?
  11. BLUDICE
    BLUDICE
    I really like the way your car sits - how did you lower it?? Aero springs - 4" blocks??
  12. bobss396
    bobss396
    I almost put them on my '59 but was afraid of marking up the stainless or paint. Is there a way to mount them with no collateral damage?
  13. EchoOfGecko
    EchoOfGecko
    Nope, just through the outside... it's pretty beefy sheet-metal there, and these spotlights aren't very heavy.
    Thanks! This is with 4" blocks in the rear, and the original chopped springs before I swapped them out. I've since installed the Aerostar springs and it does sit a couple inches higher in the front at the moment; I think I might cut a coil out.
