Penetrant/Lubricant
Discussion in 'The Hokey Ass Message Board' started by adjustablejohnsons, Dec 6, 2009.
  1. My old military pal, an armorer, sent me two cans of this stuff.
    I first used it in my .44 Special. The action is remarkably smoother. Tried on a frozen bolt....worked faster and better than anything I've ever used. It ain't cheap.
    http://www.strike-hold.com/
  2. 94hoghead
    94hoghead
    I like BLAST myself...I've never seen this brand.
  3. fab32
    fab32
    After using Gibbs Brand I won't waste my time or money with anything else. You can check it out at Roadsters.com. Dave Mann the owner of the site is a member here and you can order it through his site.
    Frank
  4. Jalopy Jim
    Jalopy Jim
    I use a mix of ATF and acetone, works better than any store bought mixture I've tried and is cheap, just watch out for the fumes.
  5. hotrod-Linkin
    hotrod-Linkin
    keep an eye on that.44 spl. penetrants sometimes will eat metal.
  6. 73RR
    73RR
    If a military armorer is using the stuff on the job you can be ***ured it won't cause damage to any weapon parts.
  7. BangerMatt
    BangerMatt
    If it's eating metal, it's something other than penetrating oil.
    I prefer Kroil myself.
  8. Swiss50chevy
    Swiss50chevy
    GM Rust Penetrant and Inhibitor part#88862627, sneek a can home from work and use on my projects. Works wonders.
  9. man-a-fre
    man-a-fre
    Agree with banger matt on the Kroil,can't be beat without using heat.
