Technical "PERFECT" Reproduction 30-31 Roadster Wheel Well Panels
Discussion in 'Traditional Hot Rods' started by The37Kid, Jun 11, 2022.
  1. The37Kid
    The37Kid
    DSCF1363.JPG DSCF1364.JPG Looking for feedback from those that have bought 30-31 Roadster wheel well panels. I want to save as much of the original tin, DO NOT WANT to replace the whole panel. Who makes panels with the three rolled beads that are the same width and fit the originals? I think Brookville does, but who has installed a pair? Does someone have the factory matching dies to roll out pieces? Thanks! Bob DSCF1363.JPG DSCF1362.JPG DSCF1364.JPG
  2. atch
    atch
    Hey 37,
    This is in no way a criticism of your plan, but why don't you want to replace the whole panel? I'm definitely no metal man, but it seems to me that keeping most/all of what you have will require more work than replacing the whole panel without being any better.
    What am I missing?
    I'm here to learn; not to critique others' work or ideas.
    Just Gary likes this.
  3. The37Kid
    The37Kid
    I've had the Roadster body since finding it in 1962, just want to keep as much as I can.
    Outback, 303racer and 26 T Ford RPU like this.
  4. atch
    atch
    Fair enough.
  5. millersgarage
    millersgarage
    none of them fit perfectly.
  6. missysdad1
    missysdad1
    I just got through repairing the wheel well panels on a '31 roadster using Brookville Roadster panels. As in the photo I only replaced the bottom 4" and solid **** welded them to the originals (the first picture was taken when the welding was still in progress). Yours are pretty badly butchered so I would use the BR panels after cutting away all but about 2" of the original wheel wells on yours. If you are not into **** welding you can lap weld them together which is much faster and easier. And that area isn't noticeable when the car is finished so a little filler will go a long way towards making it look right.
  7. 31Apickup
    31Apickup
    On my coupe I wanted to do the same, just replace the very bottom. Bought a pair of panels thru Snyder’s, the beads weren’t as deep as the originals. A made up a die (photos in my coupe build thread), and pressed the bead deeper in my press, then they lined up.
    The37Kid likes this.
  8. The37Kid
    The37Kid
    Thank You! That photo is what I hoped the repop panels would look like.
    Bob
  9. hotcoupe
    hotcoupe
  10. hotcoupe
    hotcoupe
    In my previous post the images depict front fender skirts on my '48 Indian Chief. The first image was a practice piece, the second image is the final product temporarily installed on the fender
  11. chev34ute
    chev34ute
    This is something you can do yourself if your prepared to put the time in. The tool needed is a bead roller.
  12. The37Kid
    The37Kid
