Customs period corect motor
Discussion in 'The Hokey Ass Message Board' started by BICKFORD, Jul 19, 2011.
  1. BICKFORD
    BICKFORD
    from CA
    hi all
    i have 1 51 chevy 2 door sedan. right now im runnng a 64 283. i want to put a period correct motor in it. i dont want a straight six. i want v8 something pre54. tryng to figure out what would fit and look like someone built it in 54. thanks for any nfo or pictures.
    jason
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Of all the pre-'55 Chevies I've seen that still had vintage OHV V8 swaps intact, Olds leads the pack.
  3. F&J
    F&J
    Cad or Olds. Nailhead would still be too new, and harder to get in 54. I like Olds, but I think a Cad would be the one I'd use in that car.
  4. Yea they were pretty popular engins back then. After that Caddy engines.
  5. BICKFORD
    BICKFORD
    from CA
    i just want to make sure a cadillac will fit in my 51 chevy. i was told they are bigger motors. ive never seen one up close
  6. Either will fit.
    The '49-'54 Chevy wasn't a real popular car for engine swaps for what ever reason.
    Something else that would be doable for period correctness would be the blue flame six with the export package. Think Corvette.
    I had a '54 Wagon with one, it was purchased that way. pretty cool old wagon.
  7. 49ratfink
    49ratfink
    it's 2011. put whatever you want in it.
  8. norm ricardo
    norm ricardo
    you can do a 1955 engine swap with a 265, or hop up that 6 with a split exhaust manifold and have that awesome exhaust rap
  9. That awesome rap ans six cylinder now that's an oxy-*****. I guess if you are into Piper Cubs the sound is as good as it gets. :rolleyes:
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Don't like 235s with split exhaust, huh? What are ya, one o' them damned commies?
  11. hartman601
    hartman601
    from Tulsa, OK
    My grandfather who is now close to 80 had a 51 chevy with a 235 and a split manifold when he was a teenager. He always would carry on about how that was the thing to do in his day. I didn't get it 10 years ago, but I sorta do now.
    I know you are committed to the v8, so I won't try to sway you.
  12. norm ricardo
    norm ricardo
    alright if the 6 doesn't work for ya then put a Y block in it!
  13. partsdawg
    partsdawg
    from Minnesota
    Studebaker.
    Dare to be different.
  14. Mr48chev
    The ****** must have been half asleep because I know he knows that "rapping" the pipes came long before that stuff some clowns think is music.
    Back when pipes had to have a sweet sound rather than just be loud and we knew the sound of our buddies cars from three blocks away.
    Ok, what period is the style of the work on the car set in including body work, paint style, wheels/tires/hubcaps and what not.
    It doesn't make much sense to blow 3 or 4 k to change engines to a "period correct engine for the early 50's if the style of the car is early 60's as far as paint, wheels and custom work goes.
    If the whole theme of the car is set in 1953 and you have nothing on the outside or interior of the car that showed up at a later date then swapping to an early Olds or Cad engine might be interesting. but if the car is decked out with mag style wheels and lace paint or paint that came later why blow the money on the engine that could have been better spent on paint or interior? And most "custom" car guys could give a rip what is under the hood of a custom as long as it is dead nuts reliable as they refuse to open the hood at a show anyhow. Even on my 48 I hate the look of it with the hood open and never open the hood at an event unless it is requested.
    But everyone chooses how to spend his "car money".
  15. I'm not partial to 235s, I don't like all six cylinders equally. :D:D
    I just never did like the way they sounded, like I said Piper Cub. I wonder what one would sound like with flow masters? :D
  16. d2_willys
    d2_willys
    from Kansas
    331 hemi, very period correct!
  17. plymouth1952
    plymouth1952
    Sir Hemi allways works well.
  18. scrap metal 48
    scrap metal 48
    With a 283 you already have a period correct motor.. Why change........
  19. squirrel
    Period correct engine swap....hmmmm....in my mind's eye I see big holes hacked in the firewall, covered crudely with metal from old oil cans attached with slot head screws, mounts made from angle and pipe cut off with a torch and brazed to the frame, etc.
    Olds if you can't find a caddy
  20. badlefihand
    badlefihand
    331 cad was a very populer engine in those years but the 6 is the one.
  21. handyandy289
    handyandy289
    from Georgia
    GMC big six or be very different and try a Hudson 6
  22. d2_willys
    d2_willys
    from Kansas
    Buick straight 8!
  23. teddyp
    teddyp
    olds was the motor that most guys used but in 1964 i found a 51 chevy conv. that had a 322 nailhead in it it was built in the late 50,s and in bad shape when i got it but it look like it was made for it
  24. HEATHEN
    HEATHEN
    from SIDNEY, NY
    One of my old small magazines has a 322 powered '52 Chevy in it, and they cured the LH exhaust manifold/steering gear interference problem by splitting the stock manifold and welding two outlets to it, making a pair of two cylinder manifolds that were then connected by a Y pipe.
  25. 55chevr
    55chevr
    Olds were popular but in the 50-s the most popular engine was and still is the SBC.
  26. badshifter
    badshifter
    But...Piper Cubs were/are 4 cylinder engine powered...... Even the Super Cubs were flat 4 powered.
    I know, has nothing to do with a period correct 1954 car engine.
  27. 63Biscuit
    63Biscuit
    from Hudson, WI
    I learn something every day I get on the HAMB.
    A "period correct" 235 does sound a helluva lot like a small airplane, 'specially with split pipes, Porters and a good rev with a 3-speed.
  28. seventhirteen
    seventhirteen
    from dago, ca
    not sure what would be cooler than this with 3 deuces
  29. Never2low
    Never2low
    When I bought my AD, the first show I went to, the guy at the gate had a big smile on his face as I pulled up. "Nothin sounds like a staight six. Got a couple Thrushes on there don't ya?" My first hinkling that "Inliners" had a devoted following, and weren't just a couple oddballs on the fringe of hotrodding.:D
