Technical Perplexing clutch issue
Discussion in 'The Hokey Ass Message Board' started by 63Biscuit, Mar 19, 2015.
  1. 63Biscuit
    63Biscuit
    from Hudson, WI
    Hi all-
    I have a perplexing clutch question, but let me give you a touch of background. My '63 Biscayne is powered by a hot Chevy 292 L6 (built by Tom Lowe, here on the HAMB), making somewhere in the neighborhood of 300hp and 300lb-ft. Last year, the original-to-the-car Saginaw 3-speed died, and the Napa parts counter clutch went with it: the diaphragm adjustment straps all broke allowing the clutch ***embly to fail. I had a local transmission shop install a Richmond Super T-10 and a new heavy duty clutch that was fit to the original-to-the-car but freshly machined and balanced 153T steel flywheel.
    Driving it last summer, I noticed a gradual increase in vibration in the car as engine speed increased. At first, noticed vibration at around 4500RPM, then 4000, then down as low as 3000RPM. On the last drive of the season, in October 2014, I was accelerating onto the freeway when I heard a "crunch - zing - tinkle,tinkle,tinkle" noise in the bellhousing. I drove it 5 miles home and put in the garage for the Winter.
    Fast forward to yesterday, when I got the car back to the transmission shop that did the install. It turns out the same clutch failure has occurred - all of the diaphragm adjustment straps have broken. My shop hasn't ever seen this happen outside of missing a shift at high RPM (i.e., intending to go from 3-4, but going 3-2 instead) - which hasn't happened in this car. While I enjoy driving it kinda hard, I certainly wouldn't say I've been abusing the motor, trans, or clutch. We're kind of at a loss for the root cause of the failure.
    If you've encountered issues like this before, or know of possible solutions, I'd sure appreciate it if you could share your wisdom. Thanks in advance.
  2. wbrw32
    wbrw32
    I would use a three finger Borg & Beck Pressure plate rather than the diaphram type
    302GMC likes this.
  3. Me too.
    I am going to be honest while 300 ponies is pretty impressive for the 6 it is not impressive enough to be eating clutches. No offense intended.
    I have run them but never really cared for a diaphragm pressure plate a 3 finger is what I prefer if I have a choice and borg n beck makes a good product.
  4. wbrw32
    wbrw32
    I forgot to mention,,Did your trans repair shop use a new,correct T.O brg ???
  5. Timbofor
    Timbofor
    If it chewed the diaphragm in the area around the throw out bearing I'd suspect that to be the root cause. If it's further out near the pivot area I suspect it's making contact with something it shouldn't. But that would make some serious noise. Another thought is your clutch may be over traveling p***ed it's ideal release point. Might need to reduce your pedal ratio or add a stop to it. Diaphragms don't like to be over traveled like that. If you have had to make multiple clutch adjustments, it would be indicative of bending the fingers inward.
  6. Over travel on the clutch- man what a problem to have there. Most guys can't get enough travel and the damn thing is so heavy.
    Since 2 clutches went the same way, it should be easy to find the problem.
  7. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    Two different transmissions and same failure and you mentioned vibration I would look at the pilot bushing or lack of one.
  8. 63Biscuit
    63Biscuit
    from Hudson, WI
    No offense taken PnB. Agreed that its not enough to be eating clutches, nor am I beating it up.
  9. 63Biscuit
    63Biscuit
    from Hudson, WI
    Pilot bushing was replaced when the motor went in the car...should be good, but we'll double check it.
  10. 63Biscuit
    63Biscuit
    from Hudson, WI
    This seems to be the thought - too much travel on the clutch. The original clutch in the car was the three-finger type, and since the three-finger Borg and beck style needs more travel, it might well be a linkage ratio issue.
  11. 63Biscuit
    63Biscuit
    from Hudson, WI
    Yepper. Subbed out to Proven Force, a very reputable local shop that matched the clutch, TO bearing, and did the machining on the flywheel. Good point though.
  12. ClayMart
    ClayMart
    Were these high cone or low cone diaphragm pressure plates? Maybe some incompatibility there??? o_O
  13. 63Biscuit
    63Biscuit
    from Hudson, WI
    Not sure, but both clutches were matched as a set with pressure plate, clutch disc, and throwout bearing.
  14. Timbofor
    Timbofor
    Chucking in to see if a solution or cause was ever found.
  15. 63Biscuit
    63Biscuit
    from Hudson, WI
    Thanks for the prompt. After some lengthy discussion with the transmission shop, we moved to a custom (due to size) Borg and Beck-style pressure plate. The rotational forces, wherever they originated, that destroyed the old clutch won't affect the Borg and Beck plate. I've put about 150 miles on the car so far, and all is well. Plus, if you're in Minnesconsin, I'll give a shout out to Certified Transmission in Stillwater - they definitely treated me well during all this.
