Hot Rods pertronics ????12 volts?
Discussion in 'The Hokey Ass Message Board' started by hiboy32, Jul 3, 2009.
  1. hiboy32
    hiboy32
    from Omaha, NE
    I was wondering if you can hook up the pertronics to straight 12 volts. Can you bypass the resister?
  2. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    I run Petronics in 2 of my units. Mine are hooked up right to 12V. I think the directions tell you but I am not sure to use straight 12v. It helps if you use a Petronics coil also.
  3. chevy57dude
    chevy57dude
    Did he Pertronics deal in my '57. Ignitor 2 and a second strike box. Straight 12v. Resistors are only used to save breaker points while running.
  4. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    What he said. I also agree that you should use their coil. I made the mistake of hooking one up with an MSD Ignitor II coil and fried the box. They apparently don't like a super hot coil.
  5. Rich Rogers
    Rich Rogers
    no resistor for that system. You can use a differant coil but you have to be careful of the primary resistance. I have the original Pertronix and bought there coil with it and it fried in 300 miles. That uses a 1.5 resistance and the Accel superestock coil is 1.2. According to Pertronix there wouldn't be any problem but 1.2 was on the bottom of their scale. It's been in there now for 2 years without any problems
  6. hiboy32
    hiboy32
    from Omaha, NE
    Thanks guys. The directions showed how to hook up with and without the ballast resister.
    Just got back frombypassing the resister and.......... DAMN, that is the ticket. Now that is what I am talking about!
    Thanks for the input..
    Jeff
  7. Rice n Beans Garage
    Rice n Beans Garage
    straight 12 volts is the only way..
  8. Big Tony
    Big Tony
    I run it on my 54 with a 230 six with a flame thrower coil and no resister and it has never failed me
  9. RDR
    RDR
    just a note here guys... i burned up 2 Pertronics before finding out you never leave your key on without engine running...they don't tell you that in any of their literature...(car was warming up in d/way and died#1~turned key on to see if burned out bulb or flasher was bad#2)..Now the Pertronics II has a protection in the system so they won't do that. I run a 250 6 cyl and the engine really woke up with the pertr...but if i ever lose another it's getting HEI, as parts are available anywhere ...and yes...12V it
  10. Mopar34
    Mopar34
    I use a Pertronix Ignitor with an MSD coil and without the resistor. No problems in 10 years.
    I have also accidently left the key on, long enough to kill the battery, without damaging the Pertronix unit. If and when it dies, I will replace it with another one. Don't think they have an HEI for a 371 Olds yet.
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I got mine hooked up straight 12V
  12. 390Merc
    390Merc
    from Indiana
    I remember reading some Pertronix instructions saying not to leave the key on for extended periods of time. I have the systems in 3 FE Fords and one SBC. No problems yet.
