1952-59 Ford Pertronix ignition
Discussion in 'Off Topic Hot Rods & Customs' started by flattie38, Feb 18, 2017.
  1. flattie38
    flattie38
    from Taylor, Mi
    I finally give in and decided to convert to electronic ignition. I bought kit number 1281p6 which fits a 1957 ford distributor, with a positive 6 volt system. well it didn't even last a season, the damn thing burn't out in my garage and has sat there till today. I got a whole new unit because of warranty of 30 months. So I installed it right a way last year but, gave up working on it and let it sit for the winter. I called support tech yesterday and he gave me some tips. I have a complete circuit but, which he told me how to do, still no spark from coil. New coil bought new along with the two others that I thought were bad. I connected the wires like the instructions said to cut ignition switch wire and use the wire from the kit they're pretty easy to follow. Now ignition wire goes black directly into unit inside and then the black and white wire runs from kit to - side of coil and the +side is grounded. Still no spark at coil when removed and laid against valve cover. Took my trouble light and disconnected wire and used my trouble light for a ground and it lit when engine was rolled over. the + and the light lit.. The unit is .005 away form the electric ring. I have double checked everything and made sure everything was tight and clean for a good ground. I just am no farther today then I was last Nov. before I gave up and put the car away..................
  2. Jimmy2car
    Jimmy2car
    from No. Cal
    38
    I have Pertronix kits in all three of my cars:
    32 Ford (7 Years)
    39 Ford (26 Years)
    56 Ford (1 Year)
    All cars are 12 Volt.
    On the 56, my wiring for, or from, the module:
    Red wire to + terminal on Coil
    Black wire to - terminal on Coil
    Distance from Module to Rotor is .030"
    I have no experience with 6 Volt items at all.
    All of mine run extremely well.
    Jim
  3. Texas57
    Texas57
    I know zero about them...just thru a flag when you said fits a '57 distributor with 6 volt pos. system. '57's were 12v.
  4. 55Brodie
    55Brodie
    Distributor is just a switch; it does not matter what voltage or polarity is. I'm speaking of a points type unit. I have no personal experience with Pertronix, but people sure seem to have problems with them.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Seems the 12 volt systems are more trouble free than the 6 volt units this has come up before,If you get it working be sure and pack your old points and condenser if you go on a road trip so you can convert back if needed.
  6. Bleach
    Bleach
    It's posts like these that tell me it's best to keep points. The points themselves rarely ever fail instantly but condensers may. A bad condenser is easy to change and cheap enough to keep a few spares in the glove box.
    ems customer service and JeffB2 like this.
  7. okiedokie
    okiedokie
    from Ok
    I have used several Pertronix units with never a single problem.
  8. mikhett
    mikhett
    from jackson nj
    have one in my 62 Galaxie since 2007.No problems yet!
  9. Jimmy2car
    Jimmy2car
    from No. Cal
    I think there the greatest things since sliced bread & 7 up
  10. Bleach
    Bleach
    I've never had a points ignition related problem that I couldn't easily solve. Electronic ignition problems have stumped me to no end and haven't usually been cheap to fix. I do admit none were Pertronix. They were all OEM's.
  11. Yutan Flash
    Yutan Flash
    from Gretna, NE
    Question is, what generation of Pertronix do you have? First-generation units will fail if the car's not running and you leave the ignition switch in the "Run" position (kind of like frying a coil - been there, done that) - current keeps going through the unit and will fry after a short period of time. Second-generation units supposedly will be more forgiving if the ignition switch is left on while the car is not running.
    I've run a first-generation unit in my '63 T-bird for over 13 years and have not had a failure with the Ignitor module, but have fried two Flamethrower coils because stock mounting for coil on a '63 'Bird with A/C is horizontal: the coil wants to be mounted vertically so that it doesn't short out against the metal case when it gets warm. Right now I'm running the stock mustard-top coil and have not byp***ed the resistance wire from the ignition switch to the coil, and it seems to run just fine.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
    Interesting discussion here and on some other forums: https://www.fordbarn.com/forum/showthread.php?t=122788&showall=1 It seems that the older Pertronix units have been USA made and reliable most of the issues that have been in units made within the last few recent years may indicate that some production is now made offshore to cut costs and increase profit,MSD has recently jumped on that bandwagon and reputation is also falling,coincidence ?
  13. flattie38
    flattie38
    from Taylor, Mi
    I just bought the kit not too long ago say March of last year.
  14. ems customer service
    tried pertronix, fails with out notice, and way to easy to burn up new units. stay with the points
  15. 57Custom300
    57Custom300
    from Arizona
    As mentioned it seems like people have trouble with them or have had no trouble with them. I chose a different route. I converted my yblock distributor to a Duraspark system. Picked up doner distributors and wiring looms from the junkyard and had a few ignition modules laying around. I also had to have a points cam machined to accept the Duraspark armature wheel. I'm sure I have more in it than a Petronix system would cost but I know I have a known good system that I can diagnose and get parts for if needed. Haven't had any trouble with it in the 4yrs it's been in there and it always gets a few comments at shows from people that know what they're looking at.
