Technical Pertronix Ignitor III
Discussion in 'Traditional Hot Rods' started by PeggySue, Feb 27, 2021.
  1. PeggySue
    PeggySue
    Trying to trouble shoot Ignitor III module without pulling distributor . I have power to the coil from switch. If I use a test light in the coil plug socket on distributor cap shouldn't I have power there when I key the switch?
  2. squirrel
  3. Blues4U
    Blues4U
    from So Cal
    Before doing any more troubleshooting, sit down and do some reading on basic auto ignition systems. A system with a Pertronix Igniter works the same as a basic points style system, except take the points out and insert the Igniter, it does the job of controlling primary current through the coil. Understand how the system works first and you'll spend far less time figuring out what's wrong with your's, and wth fr less frustration.
    Here's a good article:
    https://www.carparts.com/blog/a-short-course-on-ignition-systems/
  4. PeggySue
    PeggySue
    Thanks
    Blues4U likes this.
  5. No the igniter switches the primary windings off and on. Every time the primary side is switched off the electromagnetic field collapses around the secondary windings which induces high voltage through the terminal you're checking. Your test light will not like the 10's of thousands of voltage present at that terminal.
  6. PeggySue
    PeggySue
    I probably pull the distributor tomorrow and test the module like Petronix instructions state, was just trying to short cut it. I would think there should be spark at the spark plug if it was working when cranking the engine
  7. Doublepumper
    Doublepumper
    from WA-OR, USA
    Yes, providing the plug body is grounded.
    Blues4U and PeggySue like this.
  8. Yes the plug will not fire if you're holding it in your hand, it needs to be grounded to complete the circuit.
  9. Unless perhaps if he is also holding the engine with his other hand... to find that ground.;)
    Pocket Nick and Blues4U like this.
  10. PeggySue
    PeggySue
    Thanks, knew it had to be grounded.
  11. jaw22w
    jaw22w
    from Indiana
    Three months ago, I installed an Ignitor III in my model T (350). Sitting in the shop, I got it running good enough to pull outside so I could time it without fuming out the garage. It ran long enough to get it outside, then quit after 5 minutes of running. No spark. I called Pertronix tech. He gave me a couple diagnostic checks to verify that the module was good. Even though I never called the Ignitor III a POS, the tech was pretty testy. I got the feeling that he handles a lot of "no spark" calls. I put it back in the package and returned it to Summit for a refund.
  12. PeggySue
    PeggySue
    Starting to look like that, thanks. I have read some reviews like that before I bought, but had figured any reviews you reed have some negative posts.
  13. jimmy six
    jimmy six
    Pet II’s seen to be pretty bullit proof if you use their coil. Keeping the ballast resistor maybe more so....III’s not so much.
    Cosmo50 likes this.
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    Did the " pertronix guy" that used to come on & answer all the questions pertaining to that product stop coming / posting here ?
  15. FritzFord
    FritzFord
    from Nashville
    I’ve used a ignitor II for several years with their pertronix flame thrower coil, no problems. I’ve always had good interactions with their customer service. I would recommend calling them to troubleshoot
  16. Illustrious Hector
    Illustrious Hector
    Why are so many guys afraid to pull a distributor?
    An often overlooked item with Pertronix is the clearance between the magnet ring and ignitor when the dist. shaft moves up and down.
    If not within the specified parameters, the unit will not function correctly.
    To obtain the specs the distributor must be out of the engine.
    Cosmo50 likes this.
  17. PeggySue
    PeggySue
    Not afraid to pull distributor, just was looking for short , pulled it , tested , bad, went back, installed points distributor back in.
  18. Fordors
    Fordors
    I think you are referring to @hotroddon
    his profile shows him still active here.
