Pertronix ignitor wiring?
Discussion in 'The Hokey Ass Message Board' started by 23dragster, May 4, 2011.
  1. 23dragster
    23dragster
    from U.S.
    I have a solid-state, "Hall Effect" points eliminator kit that I just installed on a Chevy V8. It has 1 red and 1 black wire. The company's website says to route the red wire to ign power, and the black to coil neg. I wired it differently, and it works. the way the company says to wire it leaves no where for the voltage to go when triggered? If the system works, will it fry is it's set-up "wrong"?
  2. Panama Red
    Panama Red
    If you run the power to a constant power source, yes, you'll burn up the module. Needs to be on switched power.
  3. squirrel
    Do you have any idea of how a coil works?
  4. hotroddon
    hotroddon
    If it is a PerTronix ignitor - you have wired it wrong and will probably fry it.
    Red Wire to coil +
    Black Wire to coil -
    12v Ignition source to coil +
    That is all. Unless you have a tach, tach signal to coil -
    Don from PerTronix
  5. Goodlife
    Goodlife
    I have Pertronix in both my hot rods and think they work great. Lots of miles and no problems.
