Pertronix missing on one cylinder?
Discussion in 'The Hokey Ass Message Board' started by 56KUSTOM, Jul 5, 2013.
  1. GMC BUBBA
    GMC BUBBA
    Thats a heat or thermal shut down, usually caused by too low of resisitance in the primary ignition circuit.
    What coil are you using , resistance is = ?????
    Are you running a ballast with the coil + ????
  2. 56KUSTOM
    56KUSTOM
    Pertronics coil.No resistor.
  3. GMC BUBBA
    GMC BUBBA
    I would suggest trying another coil..
  4. hoop98
    hoop98
    from Texas
    If you have a 40001, 40011, or 40111 coil you need a ~1.5 ohm ballast resistor in the 12 v switched feed.
  5. Engine man
    Engine man
    from Wisconsin
    Obviously they don't test each unit.
  6. 56KUSTOM
    56KUSTOM
    I found a 1.2 and a 1.8 ohm. I bought the 1.8,will it be ok? I also got another Pertronix coil.
  7. Hitchhiker
    Hitchhiker
    I just had 2 out of the box that would only run on 4 cylinders. This is for a Ford v8. rotate the exciter ring and the miss changed cylinders. put the points back in, car runs great. Never had a problem before. weird.
  8. 56KUSTOM
    56KUSTOM
    I forgot to ask if I can test by running the car long enough in the driveway.I don't wanna get stuck on the road again.
  9. hoop98
    hoop98
    from Texas
    Either will work, you should be fine now.
  10. 56KUSTOM
    56KUSTOM
    I started it with the old coil tonight and it ran for 17 minutes before we could here it missing and by 23 minutes it died. Then I put on a new coil and it started right up and ran for 1/2 hour smoothly before I shut it off. I don't know if I should expect this coil to **** out later or feel confident to take the car out. I will at least carry an extra. Is the lack of a ballast resistor causing the coil to fail?
  11. 54Buick48D
    54Buick48D
    from Maryland
    The ballast resistor knocks down the voltage to the coil so the coil has a long life firing. It usually knocks voltage down to about 8 or so. You will want to keep the ballast resistor. The ignitor should be tied to the 12 volt side of the ballast resistor as the ignitor needs 12 volts. This is how I interpret the Pertronix instructions for a system with a ballast resistor.
  12. hoop98
    hoop98
    from Texas
    Unless the coil has an internal resistor you must have a ballast resistor for that system !!!
  13. GMC BUBBA
    GMC BUBBA
    Yes , feel how hot the coil gets when running.........:eek:
  14. hoop98
    hoop98
    from Texas
    Pertronix states that their 1.5 ohm coil does not require a ballast resistor.
    Here is a look at the current going trough the coil at 13.5.volts.
    If the coil continues to run hot I would add some ballast resistance for peace of mind.
    Is a very low value which could be a good compromise.
  15. 40FordGuy
    40FordGuy
    #13,.....I still run the same Pertronix since 1986... I'd say that's rather ok quality.
    4TTRUK
  16. 56KUSTOM
    56KUSTOM
    Ballast resistor installed,moved coil to firewall so it wouldn't get as hot. Runs good for now.Coil still get hot,is that normal?
  17. hoop98
    hoop98
    from Texas
    Warm is ok, if it burns your hand I'd be worried, as Smokey says, it will stop making noise. If you have a voltmeter check the voltage at coil positive while idling.
  18. Engine man
    Engine man
    from Wisconsin
    They might have made them better 25 years ago. Like everyone else, production may have been moved to China.
  19. Hitchhiker
    Hitchhiker
    Still says made in USA on the boxes
  20. 56KUSTOM
    56KUSTOM
    Well,even though the coil says it's a 1.5 resistor,we figured out the right way to hook up the other resistor. It ran like ****. Apparently that cut too much voltage,so we by-p***ed it again. I guess I will carry a spare coil with me and see how far I get.
  21. hoop98
    hoop98
    from Texas
    I think 1.8 was too high. If the coil runs hot try a much lower resistance resistor. Somewhere between .25 and .75 ohms.
  22. 40FordGuy
    40FordGuy
    56,.....Most 12 v. systems require the ballast resistor ; I believe it's possible for the lack of one to cause early coil failure.
    4TTRUK
  23. 56KUSTOM
    56KUSTOM
    Well,I called Pertonix and the tech guy said the 1.5 built in is all you need and the coil could have been faulty.
  24. hotroddon
    hotroddon
    We still build ALL the PerTronix modules in San Dimas CA. :D
  25. hoop98
    hoop98
    from Texas
    That's "cool", problem solved. However, if you are still concerned about a hot coil or thermal shutdown here is a .2 ohm "Corvette" resistor.
    It will cool down that coil but only cut about .4 volts at higher RPM. It will mostly lower the voltage at lower RPM.
    The 1.8 Ohm resistor you tried cut the voltage down to about 6 way too low.
    Here is about what kind of heat you are generating with the Vette resistor.
    Cooler and you have a Vette ignition!!!
  26. Rich Rogers
    Rich Rogers
    I had my coil go bad and instead of waiting for one to get here I called Pertronix. They told me that 1.2 ohm would be fine although it is at the bottom of their scale. That's when I went to NAPA and got an Accel Superstock . It's been in there for 4 years with no failure and I keep the Pertonix replacement just in case...
