Pertronix Question 6 Volt Positive Ground
Discussion in 'The Hokey Ass Message Board' started by MBL, Dec 27, 2006.
  1. MBL
    MBL
    Howdy all...Tim here. I am using a pertronix ingnition in my 1955 Dodge..It has worked pretty well so far. I find that at times I could probably use a hotter spark though.
    Currently I am using the stock coil, but I know that they have the flame thrower coils. Problem is...I can't figure out which one to buy...I know I should only use the Flamethrower I coil..but it doesn't say if it would work for a 6 volt pos grnd system...
    It may only be for the 12volt systems....
    The company has no way to contact them to verify...any ideas?
    Thanks
    Tim
    MBL
  2. bastadical
    bastadical
    from Fenton, MI
    I called the number on their site to get all the help I could ever need when I was ordering the ignitor system for my Buick...
    www.pertronix.com
    [FONT=Times New Roman, Times, serif] Phone: (909) 599-5955
    Fax: (909) 599-6424
    [/FONT][FONT=Times New Roman, Times, serif]440 East Arrow Highway
    San Dimas, CA 91773
    [/FONT]
  3. MBL
    MBL
    Cool thanks! I will give them a call.
    Tim
    MBL
  4. last time I checked, Pertronix didn't make a kit for any of the flathead six Mopar distributors, and, as far as I know, there are no 6 volt kits anyway.
    I read on the Inliners website that you can combine parts of two different kits, and with some modifications and glue, you can make a conversion, but you're still stuck with 12 volts.
    A better choice would be the Langdon's Stovebolt Engine Co. converted small HEI, also strictly 12 volt.
    If you're going to stay 6 volts, you're limited to points of some type. I have an NOS Mallory Magspark dual point that I am going to run, and have located an NOS 6 volt positive ground transformer box for it. Goofy thing is, I WAS planning the 12 volt conversion, but am going to forgo it now for use of the ignition.
  5. MBL
    MBL
    I didn't see any ignitors for the flathead 6...But they do have them for the V8 and for 6 volts Positive Ground. That is what I am currently using.
    I spoke to someone there and they told me the story with the coil applications...Very enlightening...I will be getting one of the coils soon.
    Tim
    MBL
  6. Dennis Cator
    Dennis Cator
    from CANADA
    I have 1948 ford flathead. Is it a a benefit to my car to simply add a 6 volt flame thrower ? Will this coil give me a little boost Making it a easier start up when the engine is hot and I am restarting up at the grocery store? Thank You
    Truck64 likes this.
  7. jimmy six
    jimmy six
    12 volts on a 6 volt starter is best for that but you sound like your wanting to keep 6 volts. I found no change in starting when I changed to a Pertronix from points, Bad/poor condensers sent me packin’.
    Truckdoctor Andy likes this.
  8. I don’t know about availability for the Mopar sixes, but Pertronix does make six volt positive ground stuff. Dad has one in his 1959 International Cub LoBoy mowing tractor. Works great and I used the six volt Flamethrower coil too. Any questions, call The Brillman Company and ask for Mr. Brillman.
