pertronix with msd blaster 2 coil
Discussion in 'The Hokey Ass Message Board' started by THIRD PEDAL -lane, Sep 29, 2013.
  1. i.have a ignitor 2 and flamethrowe 2 coil on my truc and it works great, i just got a ignitor 1 for the 170 in my ranchero and i know it works with astock coil ihave twoblaster 2 coils my buddy gave me that say they will workwith stockpoints so i would think a blaster 2 would work with a ignitor 1 , im asking cause the stock coil is damn corroded and trashed so why spend money when i have 2 coils right there , curious if its worked for others and their take on it
  2. 440 deluxe
    440 deluxe
    I used a msd coil with my flamethrower 2 with no issues. Not sure abou the 1? Call summit tech line. Good luck
  3. tedley
    tedley
    from canada
    I would always be waiting for a failure to happen with possible mismatch parts like that. Taking a chance blowing the module.
  4. upspirate
    upspirate
    If I'm not mistaken, I checked with Pertronics and they said the Blaster 2 would work with the Igniter II but not the Igniter I.
    Call them up and check
  5. Dave Mc
    Dave Mc
    Pertronix Tech Support
    PerTronix, Inc.
    440 East Arrow Highway
    San Dimas, CA 91773
    Phone: (909) 547-9058
    Fax: (909) 599-6424
  6. Hotrodmyk
    Hotrodmyk
    Yeah, check with Petronix first. I had the same question with another coil. I went and bought a Pertronix matching coil and never looked back.
  7. hotroddon
    hotroddon
    The Ignitor I likes 3Ω resistance when run with a 12v 6 cyl motor. That blaster II has only .7Ω resistance, so you would need to use at least a 2.3Ω ballast resistor with it
    Don from PerTronix
  8. so ive heard mixed views on theinstall should if using the stock coil,should i install it to the coil with no issue ive heard mixed emotions a out the factory resistor
  9. upspirate
    upspirate
    My advice would be to follow hotroddon or DubP advice (dubp hasn't chimed in here yet)
    They work for Pertronics, but for faster, call them
    When I mentioned my previous advice, I forgot that 6 cyl calls for different than 8 for some reason
