Pertronix
Discussion in 'The Hokey Ass Message Board' started by grubbygreg, Jan 24, 2013.
  1. grubbygreg
    grubbygreg
    from Indiana
    Thinking about using a Pertronix Igniter to replace the points in my stock 68 Mailbu (327/275). Any advice about coil, wires plugs or gap setting?
  2. Hi Greg,
    First, before you get flamed, you need to do a proper introduction, and read the rules. We don't really deal with much after 1965 or so around here. This is an earlier Hot Rod website.
    If you call or email Petronix, they can give you all the information you need to set your rig up. Most Petronix kits come with a correct coil for the application, and will recommend a good set of plugs (AC Delcos in your Chevy, don't bother with anything fancy or overly expensive. In my opinion) and everything else you need.
    Good luck.
    Atwater Mike likes this.
  3. After you deal with the B.S., do a search.
    You'll find many complaints/problems with Pertronix.
  4. the most important thing is the amount of resistance in the coil too much and youll burn up the pick up coil been there done that
  5. HOTRODPRIMER
    HOTRODPRIMER
    I love mine,,got them in 3 cars,,no problems. HRP
    volvobrynk likes this.
  6. Kerry
    Kerry
    What's funny is he's been registered longer than either of you guys.
  7. Yup, sure are a ton of people that just think a coil is a coil is a coil. I figured it out pretty quick after buying a couple at $30 a pop as a kid.
    Didn't even notice that. Oh well, I've seen many people that have been around a long time doing stuff all wrong.:D
  8. I'm not holding that against him! :rolleyes:
    I was referring to the flack he'll get from others. ;)
  9. HOTRODPRIMER
    HOTRODPRIMER
    Yeah,,and he has a 57 Vette 34 Chevy coupe. HRP
  10. canadianal
    canadianal
    from canada
    ive honestly had poor luck with them had 2 pertronics and a crane unit in my bucket never did fail but eventually they would start misfiring at high rpm changed coils wires etc . The crane worked the longest but also failed it started misfiring all over the firing cycle.finally went to a Hei and havent toutched it since.
    just my 2 Cents
    Al
  11. J'st Wandering
    J'st Wandering
    I did the same back a few years. Put the pertronix in a '69 Chevy. Ya, I know, it is an o.t. car. I ran the stock coil, did not know any better. Worked fine. The pertronix needs a full 12 volts so remove any ballast resistor.
    Neal
  12. lizzard71
    lizzard71
    from Phoenix AZ
    Used one for 10 years plus no problem in a mild SBC, stock coil and later a Petronix coil. Set gap per instructions, no problems.
  13. big creep
    big creep
    make sure you get the petronix coil, and get the igniterII, it has an auto shutoff so you dont fry it if you leave the key on.
  14. triumph 1
    triumph 1
    I have run several pertronix ignitions w/o any problems. I do use their coils though.
  15. eddie1
    eddie1
    I've been very happy with mine. Mind you it's a 65 Coupe de Ville so there is no high rpm involved.
  16. mykeb
    mykeb
    from Virginia
    I've been running one for a couple years now on my 223. Opted to try to avoid coil mismatches by also installing the Petronix coil. Nothing exotic. Had no problems and the engine has been running well. The instructions for my unit stated to leave the ballast resistor installed.
  17. Dave Mc
    Dave Mc
    Here is a Thread with alot of input on Pertronix, I have one in my 29 "A" with 302 Ford=Starts faster and performs Flawlessly so far, seems having the right coil is Important to keep from Frying the Ignitor ll and you can't leave the key ON while working on wiring issues unless you disconnect the Power + to the Coil while doing so
    http://www.jalopyjournal.com/forum/showthread.php?t=751510
  18. denis4x4
    denis4x4
    from Colorado
    I've used them in at least 25 cars, trucks and boats over the past 40 years. The only time I've had issues (twice) was when I failed to follow the installation instructions and when I used the incorrect coil. Currently run Petronix units in a '60 Thunderbird, '85 El Camino, '31 banger and a '32 banger with a CRAGAR head without any issues. Just remember; the advice you get here is worth exactly what you pay for it!
  19. zep058
    zep058
    X2 on getting the II
  20. Dan in Pasadena
    Dan in Pasadena
    Hmmm....A shop installed Pertronix on the 283 in my '55 Chevy truck. Runs great but they left the stock (or whatever was already in there) old coil in it. Old cause it was so crappy looking on the exterior I gave it a light sand and painted it. Sounds like I should go looking for a FLame Thrower coil, huh?
    How do I know which of these I want? I'm not even certain if I have the Ignitor or the Ignitor II setup?
    http://pertronix.shptron.com/
  21. HOTRODPRIMER
    HOTRODPRIMER
    Yeah, HRP
  22. dirty old man
    dirty old man
    Sure, you can run a Pertronix, with correct coil and resistor. But question: Why???????
    For a stock, or nearly so, sbc in a non trad, OT car I'd use OEM GM HEI. Then you got something durable with replacement parts readily available everywhere if ever needed.
  23. Rattle Trap
    Rattle Trap
    I have run them on many different cars over the years. Never a problem. Use their coil for sure. Throw the points in the glove box just in case. Though I think you won't need them.
  24. Buddy Palumbo
    Buddy Palumbo
    It seems like we've installed a hundred or more Pertronix units in customer's cars over the years with no issues. As others have pointed out , be sure that your coil has the right ohms of resistance (1.5 for a v-8) . I just ordered a Pertronix Ignitor & Pertronix coil for my Shoebox a few days ago - that's the way I'd go if I were you . Easy Beasy !
  25. Parts48
    Parts48
    from Tucson, Az
    I have Petronix in the 53 Stude..but in others more OT..I use GM HEI.. Haven't had a problem with either. The HEI runs for years in millions of newer GM cars..
    Why not yours..?
  26. fsae0607
    fsae0607
    I concur. If you go HEI make sure to use the heat-dissipating grease under the module!!!
  27. J'st Wandering
    J'st Wandering
    But even in an o.t. car, they look ugly.
    Neal
    beachbum jim and volvobrynk like this.
  28. 296 V8
    296 V8
    from Nor~Cal
    U Hall used them back before OEM electronic ignition.
    Out of 21 iv used only one has failed and it was a 15 + year old used one from a U Hall
    The best part of using them is you can put the points back in a pinch … you cant do that with a POS HEI …. your walkin
  29. Zookeeper
    Zookeeper
    Not all GM cars run for years. I had a module fail in a nearly new GM truck. Parts fail regardless of manufacturer or whether it's OEM or not. My Pertronix II has been working flawlessly since '08 and I have no reason to think it won't for years to come.
  30. I've been using them since '94, have them in six car/trucks including my Uni that I race. Never had a problem. I've never put one in a chebbie and I think they are a bit different than the set up for the Ford or my Lucas dizzys. Regardles I still keep the points and condensor in a bag in the glove box, though never had to use them.
