Technical Pete & Jakes ADJUSTABLE REAR SPRING HANGER KIT
Discussion in 'The Hokey Ass Message Board' started by 48stude, Feb 11, 2023.
  1. 48stude
    48stude
  2. 1946caddy
    1946caddy
    from washington
    No, nor would I. The problem is that the threaded rod could be a breaking point if the weld were to break or the metal failed. A grade 3 bolt will hold up better than a grade 8 bolt will after welding on it.
    There's nothing that will keep the spring from going straight to the ground if that bolt breaks.
    Several manufacturers have eliminated this problem. (see example)
  3. krylon32
    krylon32
    from Nebraska
    Those Forged steel hangers you show above are a nice product. It's a shame they weren't made with the right dimensions.
    Nailhead Jason and alanp561 like this.
