Hot Rods Pete & Jake's Super Bell brakes.....any feedback?
Discussion in 'The Hokey Ass Message Board' started by louder50, Sep 1, 2021.
  1. louder50
    louder50
    from Michigan
    I am considering this setup on my fenderless 28 Model A sedan build but can't find much feedback about them. Only other option I'm considering is the Lincoln style drums but if these have worked good for people I will most likely go with these. Anybody running these?
    gnichols likes this.
  2. da34guy
    da34guy
    Run em on most of my builds. Never a problem
  3. MMM1693
    MMM1693
    Have a complete P&J front end under my coupe and no problems. 4th summer and 15,000 miles.
  4. KevKo
    KevKo
    from Motown
    I don't think P&J makes a sub-par product. Period. So good brakes but not really a HAMB look. So you have to decide what you want.
  5. 26hotrod
    26hotrod
    from landis n c
    My coupe was built with P&J brakes back in the early 80's. I've has the car 24yrs and they work great. Parts are available from P&J if you need them and the pads from NAPA. Great tech info too...........
  6. louder50
    louder50
    from Michigan
    They sound good to go then. I just can't decide between these and the Boling Bros Lincoln drums. They are both about the same money.
  7. pprather
    pprather
    On the P&J brakes the caliper and pads are Wilwood. They work fine and are easy to service.
    The rotors are cast iron, I'm not sure of the source. The edge of rotor, which shows, will rust if not painted or nickel plated.
    The caliper brackets are available polished, but look better if chrome plated.
    They function fine and overall look good.
