photo?
Discussion in 'Questions & Suggestions' started by old beet, Mar 30, 2004.
  1. old beet
    old beet
    pics
  2. old beet
    old beet
    help
  3. k-member
    k-member
    With what? looks like ya finaly did it..YEAaaa. [​IMG]
  4. old beet
    old beet
    Those are the only ones small enough........OLDBEET
  5. old beet
    old beet
    kkkkk
  6. old beet
    old beet
    lllll
  7. 41ChevyTrucker
    41ChevyTrucker
    Forget those detailed Photoshop instructions I gave ya? [​IMG]
    Refresher course:
    Go to your image folder. Right click on the image you want to resize and go to "Open With..." then choose "Adobe Photoshop" Adobe Photoshop opens up.
    Then in the top menu go to "File" then "Save For Web". Then a new window pops up.
    On the right make sure Settings dropdown is to "JPEG Low" or "JPEG Medium". Next below that is a tab "Image Size" click that. Enter a number like 600 for the width. Then click "Apply".
    Your image should resize and below the image you should see the new file memory size. (Should be below 70k for HAMB so if it is not then make is smaller width or switch to JPEG Low in above step)
    Once the filesize is good then click "OK". Then the File Save box pops up. Use the drop down box at top to go to your "Desktop" then double click the shortcut to your photo folder. Then give it a filename and click save.
    PM me if you need more info
  8. k-member
    k-member
    41ChevTrucker, I tried to explain it kinda like that to him, but it was like Ray Charles teaching Stevie Wonder sign language, or how to weld.. [​IMG] Thanks,I hope that helps him better, he has alot of good pics.
