I'm after pics of how you guys mounted the pedals in your Model A Ch***is. I'm in need of pics of cars with three pedals, but mainly wanting to see how the brake and clutch was mounted.
Utalising the original pedals and handbrake lever: Not my A, but mine's having the same pedal treatment.
Here is one of the best threads I have seen. http://www.jalopyjournal.com/forum/showthread.php?t=210569 Druss using a cable actuated clutch in his A Vicky
Cheers for all the pics guys. That helps a lot. I'm wanting to mount them to either the rails or the crossmember i made, which is similar to Corn Coupe's. I'm using original pedals, and that thread about doing a clutch cable will be very helpful, because i'm using a LHD bellhousing and the pedals are on the RH side, so i w***n't sure how i'd be able to make it work.
