Pic request....Rare SBC speed equipment.
Discussion in 'The Hokey Ass Message Board' started by SinisterCustom, Aug 29, 2008.
  1. Here are a couple I haven't seen posted yet. D.
    Schieffer Mag-Chevy:
    Cirello Frankenstein Mag-Chevy (no cap):
  2. SinisterCustom
    SinisterCustom
    Damn....
    Those mags are cool....do they have any advance to be streetable?
  3. skunx1964
    skunx1964
  4. I saw this at Pebble Beach and it is CRAZY. Talk about over-carburation.
    Some super cool stuff here. I really love the Schieffer and Cirello magnetos, and the Roto-Faz.
  5. HOLLYWQQD
    HOLLYWQQD
    from central NY
    i haven't seen one of these in this thread yet
    NICSON SBC timing cover w/motor mounts
    Shot at 2008-09-18
    Shot at 2008-09-18
    Shot at 2008-09-18
  6. tmacracin
    tmacracin
    I want one! Very Cool:)
  7. Bob W
    Bob W
    from Here
    I would say that engine never came out of a 57 Vette. Some other Chevy owned it .
    Bob
  8. I built my first hot rod, a 30 Model A coupe in 1958. The SBC was three years old and everyone wanted one. But I had to settle for a running $15 flathead out of a salvage yard.
    Picture shows Fenton SBC headers as installed on Garry Bennett's 1932 five window coupe. Note the way the frame/motor mount has been modified for clearance.
  9. rouye56wingnut
    rouye56wingnut
    from mn.
    How about a Pete Jackson front mounted distributor set up .
  10. E.C.
    E.C.
    from Tx
    Double Lobe cam or should I say 1/4 speed cam... I will use this cam in my next Hot Rod build... E.C.
  11. Bob W
    Bob W
    from Here
    You drive in first gear ? Double Lobe ?????
  12. SinisterCustom
    SinisterCustom
    E.C.....man that's killer!
    I just saw an ad for that in one of the old HOTROD mags I bought from a fellow Hamber...Dec. 1960. Schaller Cams. $315 Introductory price....pretty spendy in '60!
    Looks like you got the whole shebang!
    Let's us know how it runs once ya get 'er installed.
    *EDIT* Here's the ad.:D
  13. skunx1964
    skunx1964
    what kind of lifters go with that?
  14. SinisterCustom
    SinisterCustom
    The ad says "drop in straddle-lobe roller lifters"....
  15. Bob W
    Bob W
    from Here
    The Cam is for a 265 Chevy.
    Bob :)
  16. E.C.
    E.C.
    from Tx
    The whole shebang for sure. $315 back in the early '60 for a cam kit is pretty high.I'm going to use new roller lifters because they are cheap. When I put it on the Dyno I'll record it on video like my last engine.
    Thanks.
    265 **** unless they have a 1/4 stroke crank. haha
    I'm thinking .060 283
    E.C.
  17. Weasel
    Weasel
    These?
    A Tudor likes this.
  18. Bob W
    Bob W
    from Here
    Well they may ****, but it's still a 55-56 cam for a 265.
    Bob
  19. E.C.
    E.C.
    from Tx
    Let me guess you used one back in the day. Its not going in a 265... The notch on the back journal doesnt matter.
  20. THE CHIEF
    THE CHIEF
    from MIAMI
    i dunno wat this is but looks cool, any one know anything about this?
    [​IMG][​IMG][​IMG]
  21. Bob W
    Bob W
    from Here
    Nope never used one of them. Probably to-day's grinds would work better on the street. What are your specs. Is that a gear drive ? Gear to gear or are there idler gears so the cam doesn't spin backwards ?
    Bob
  22. Bob W
    Bob W
    from Here
    They are neat looking, back in the early 70s I think Edelbrock and Weiand made them. You could run a single 4BC or switch tops and have a cross ram with dual 4s.
    Bob
  23. THE CHIEF
    THE CHIEF
    from MIAMI
  24. bastard
    bastard
    from colorado
    here is a little info on it. I have one that has been in the family for years.
    The Smokey Yunick-designed Smoke (or Smokey) Ram SY-1. This one is the most different from the others--it was designed from the beginning to use a single four-barrel carb. The SY-1 has been out of production for many years. It was cast and sold by Edelbrock. Smokey said this was a particularly good manifold for small-displacement, high RPM engines. This manifold was written about in the November 2002 issue of Car Craft. They found excellent midrange power, when installed on their test engine using a Holley 750 carb. The SY-1 added 23 ft/lbs of torque at 4,600 rpm, but subtracted 17 horsepower from the peak reading as compared to the Victor manifold it replaced. (They did not say how much carb tuning was done, and they didn't list the engine displacement.) The manufacture and sale of this manifold caused some hard feelings between Smokey and Edelbrock, according to Smokey's autobiography. I have heard--but not verified--that Edelbrock issued a "mixture distribution fix" for this manifold, with instructions on where to weld-in some tabs or dams on the plenum floor to even-out the fuel distribution. I have seen manifolds that claim to be reworked in this manner; but I don't have a copy of the actual instructions to verify the work was done right.
  25. rodncustom
    rodncustom
  26. SinisterCustom
    SinisterCustom
    Yeah, looks like a type of gear drive....but not like a Pete Jackson, etc...There is a gear on the crank, which turns the big gear, the little gear in the middle turns the cam....it's a planetary kinda deal...turns cam at 1/4 speed, rather than 1/2?
    The ad said for 265-283, with new applications to be released later. I wonder if any ever were made for other engines?:confused:
  27. E.C.
    E.C.
    from Tx
    Little gear on crank and a pretty big gear on cam and the cam spins backwards. I know there have been other double lobe cams for other engines out their, but they are pretty much one offs. If I do happen to hurt my cam I know and ol boy that can grind me a replacement cam to the specs I want.
    E.C.
  28. rondobandy
    rondobandy
    A friend of mine found a picture if my manifold here, taken at the Hot Rod A Rama in Tacoma 2007.
    Does anyone know the history of the Nicson 2x2 Intake??
  29. BlackCherryImpala
    BlackCherryImpala
    from Girard, KS
    I saw one of those Creitz intakes at the swap meet in Springfield, MO. It was for a single four barrel but had the flat area just like the one pictured from front to back. It certainly looked different. I had never seen one before. If I were a rich man. The guy was asking $350 for it. I probably should have bought it anyway.
    BlackCherry
  30. SinisterCustom
    SinisterCustom
    Ahh...ok, I see now....from the ad it looked like there was another gear involved.....
    Here's a cool Weiand timing cover....
    Kelly Burns likes this.
