Pick your MOTOR & Choose your TRANY
Discussion in 'The Hokey Ass Message Board' started by Cody&Lauren Mohr, Oct 2, 2009.
  1. 93NotchLX
    93NotchLX
    from Minnesota
    A cammed/carb'd 300 I-6 Ford would be cool.
  2. YAY!
    There are N/A options for these engines, come with killer 5speed transmissions and actually have similar dimensions to the Chevy sixes. I'm not trying to convince you to do this, just showing you the options. With a bit of creativity you could really dress one of these up to look like a classic Euro engine.
    Want to keep it GM? How about a single overhead Pontiac six..
  3. Cody&Lauren Mohr
    Cody&Lauren Mohr
    It came with a set of disc brakes.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    A 230 or 250 Chevy six will bolt up to 200R4 overdrive that will be good on mileage,Crower still has available Mileage-Maker cams I would contact them,also stay away from the ones with the intregal head,no goodies for those.HEI's are available for those as well as headers and intakes.:cool: If the Pontiac OHC used the same bellhousing? would be cool too!
  5. mj40's
    mj40's
    Then a 289,302 or 351 with a C6 is out? :D :D :D
  6. Pontiac OHC has a BOP bellhousing so the TH200 4R trans would fit.
  7. Cody&Lauren Mohr
    Cody&Lauren Mohr
    Everyone keeps mentioning the Poncho OHC. What years, and what size is it?
  8. ricky from va
    ricky from va
    how about a v6 gm front wheel drive turned sideways ? with say a sag 4 speed tranny or a muncy. maybe even figure out how to put an intake and carb on it. or maybe go wild and put a y block or buick ,pontiac or olds 350 in the box. fule tank rad and batt under the hood with a floor for a trunk like a corvair. shit it is endless. but i guess your on a budget so you have to use whatever comes along cheap. so let that be the answer to your question.
  9. Cody&Lauren Mohr
    Cody&Lauren Mohr
    the 250 Pontiac OHC would be great, especialy a "Sprint".
  10. Cody&Lauren Mohr
    Cody&Lauren Mohr
    Hey, just found what seems like a good deal on craigslist. A 292 out of a '79 Pickup, with automatic trans for $200. Don't know if it's a TH350 or TH200R4 (No habla Espanol). From what I can gather from his (translator-son) is that it ran good when he pulled it for a V8 swap. Wikipedia says that the L25 ('77-'88) only puts down 115 hp and 215 ft.lbs. Somebody PLEASE tell me that's from emissions crap! And that it will behave MUCH better with all that removed.
    So possibly a 292 with a 200R4. Sound good? Anybody have any red-flags for that combo?
  11. Shifty Shifterton
    Shifty Shifterton
    A big red flag is 200r4s were seven years out in 79 and never installed in pickups, so it's gonna be a th350. With 30 years of wear on the rings and cam, 115hp minus the emissions gear wouldn't suprise me one bit. Neither would 105 or even 95.
    Does it have the integral head?
  12. Cody&Lauren Mohr
    Cody&Lauren Mohr
    How can such BIG motors make such LITTLE power?.......I heard that these things are kind of starved from the factory, so a bigger carb and a mild cam actually helps the efficiency.
  13. Cody&Lauren Mohr
    Cody&Lauren Mohr
    not just power of course, but economy as well.
  14. oneratfink57
    oneratfink57
    from Wisconsin
    if youre willing to do a cam and bigger carb. why not do rings and a valve job? or at least rings thatll probably get you more horsepower, never mind easier start ups, than youd think. great find though! i knew craigslist would pull through :)
  15. oneratfink57
    oneratfink57
    from Wisconsin
    keep in mind the fuel crunch days, they just made cars less powerful to SEEM like they were better on gas which in fact they werent haha damn politics
  16. Cody&Lauren Mohr
    Cody&Lauren Mohr
    there's a video of a 235 with a TBI kit on youtube. He says that he had a 4.3TBI on it then switched to a 3.8TBI. Has anyone ever done one of these? Probably not going to do right away, but someday perhaps.
  17. knuckledragger66
    knuckledragger66
    from Hutto,Tx
    The 292 is a great choice.With just headers and rejet of th stock carb it will run great and get ok fuel economy.I like the jeep 4.0 myself,because I have a 4.7 stroker with a blower going into my o/t rambler .Btw a mustang t5 can be adapted to the 4.0 very easily.Good luck and looking forward to seeing pics soon.
  18. Cody&Lauren Mohr
    Cody&Lauren Mohr
    De-tuning is a crime! A CRIME I TELL YOU!
  19. oneratfink57
    oneratfink57
    from Wisconsin
    yes just like the 2006 gto. that was DE TUNED to 450 horse i believe because it was beating the corvettes through the test track, and the $85k corvette owners wouldnt be too happy if a car half the price was beating them now would they :rolleyes:
  20. Cody&Lauren Mohr
    Cody&Lauren Mohr
    So are there any GM straight sixes that DONT share exhaust ports. I read that is the largest downfall of the chevy straight sixes.
  21. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    They share INTAKE ports. The 194-250-292 series do anyway.
    Keep in mind the 292 is a taller engine. Should be fine though.
  22. Cody&Lauren Mohr
    Cody&Lauren Mohr
    They share INTAKE ports (3) so 2 cyl. per intake. But they have 4 EXHAUST ports (so cyl. 2&3 AND 4&5) have to share. That seems pretty restrictive to me. not to mention uneven to cylinders 1&6.
  23. Cody&Lauren Mohr
    Cody&Lauren Mohr
    I think the Datsun 240z engines look cool. Maybe a 2.8L block with a 2.4L head. I've heard that set up runs GREAT. Not sure if it would have the torque to pull the truck though.
  24. zzford
    zzford
    'nuther vote for the Trailblazer I6.
  25. Splinter
    Splinter
    Here's yer motor and yer tranny. (you WERE talking about transvestites, right?)
  26. Cody&Lauren Mohr
    Cody&Lauren Mohr
    If that's the the "trany" you're used to dealing with, I believe this may be the wrong Forum for you my friend.
  27. JeffB2
    JeffB2
    from Phoenix,AZ
    Also 194-230-250 can use the same universal mount kits as a SBC,not so with the 292.
  28. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    Sounds like the way to go.I'd probably limit mods to a Pertronix and a 2/1V or 2/2V intake to help with fuel distribution.Inlines usually run fat on center cylinders to avoid leaning out the end ones.That should provide some good bang for the buck.
  29. Cody&Lauren Mohr
    Cody&Lauren Mohr
    I was just thinking about it again after decoding my VIN, the previous owner threw out the size 235, but being only a 1/2 Ton, I would think the "Thrift-Master-216" might be more likely than the "Load-Master-235". The engine wont turn over right now, it's been sitting with no carb or anything covering the intake except the leaky butterfly hood, exhaust cut off just below the manifold, no top radiator hose (but thermostat may have kept rust out, and a valve cover just sitting on top with no gasket of nuts. Would it be worth it to soak the cylinders and see if I can get it to turn? I've heard of these old engines sitting FOREVER and being able to start up after a good tune up. Is that too far fetched?
