Projects Picked up a '56 F-100
Discussion in 'The Hokey Ass Message Board' started by MrHavard, Oct 1, 2012.
  1. MrHavard
    MrHavard
    I'm not very hip on the 223's so I didn't even give it a second thought but I'll definitely look into this. I'll be pulling it soon to degrease and paint it so I'll look for numbers. Thanks for the tip.
  2. MrHavard
    MrHavard
    I totally wore myself out this weekend working on the '56. I think I went through almost 3 cut off wheels cutting off bolts to get the bed off. I finally got it removed and soaked the rear of the frame down with oven cleaner and then pressure washed it a couple times. The frame looks great, minor surface rust in areas but theres a lot of the original paint too. I am going to scuff it up a little bit and then paint it with the por-15 ch***is coat. Then I'll do the same with the front end and underneath the cab. I'll try to post some photos tonight after work.
  3. MrHavard
    MrHavard
    Cut off wheels are awesome!
  4. MrHavard
    MrHavard
    A little view from the rear, looks a lot better without the bumper.
  5. servi53
    servi53
    cool project, keep after it and keep us posted
  6. MrHavard
    MrHavard
    Well looks like I'll be getting a 352 to rebuild and use. Does anyone know if Ill have much difficulty mating the 352 to the 4 speed?
  7. nice find. solid old truck. just a thought, a 292 or 312 y block would be cool in there, they're good enigines and nobody ever uses them.
  8. you'd have to ask the ford gurus, but, a Y block may bolt up to your trans as is. thats what they had in 56
  9. willymakeit
    willymakeit
    Check the front spring hangers on the rear. This is one place they can have hidden rust.
    Nice truck. Did you check out the Ford truck Enthusasits site? There is a lot of good cheap tech on their.
  10. 206tee
    206tee
    Cool! A flying truck! I read about those when I was a kid! Nice starter project. Keep us posted on the progress.
  11. MrHavard
    MrHavard
    yeah I had a 292 in the '60 f100 I just sold. I really liked it, but Im trying to be a little more frugal on this build. Building the y cost me an arm and a leg.
  12. MrHavard
    MrHavard
    I have been on FTE but I havent posted anything on there regarding this truck yet. I looked pretty close at the front hangers on the rear when I had the bed off and everything seems really solid. Of course, Ill find out for sure if I take them off.
  13. Coach529
    Coach529
    Beautiful find.
  14. damagedduck
    damagedduck
    from Greeley Co
    cool!
    good luck with the build.
  15. Tacson
    Tacson
    Nice score Mr Harvard. There should be plenty of guys out your way with doors if you dont want to fix yours. I am on FTE with the same username. Lots of good specific info there as well as here. I may have missed it in the reading the thread what are your plans for the truck? Do you plan to travel or just scoot around say a 50-100 mile radius of your home?
  16. Airborne34
    Airborne34
    from Texas
    Wow, always wanted a 56 Shop Truck
  17. MrHavard
    MrHavard
    Honestly when I started selling my '60 the plan was to buy a 50s cruiser for the family. Then this truck came up and I couldn't p*** on it. So, the basic plan is to make it a pretty clean, well running fun truck, get it driving by spring and take it to the Nor Cal shows and then sell it.
  18. Shane Spencer
    Shane Spencer
    keep pluggin away on it bro
  19. A 352 should bolt right in if you can find the right combinations of motor mounts. A Y-block would be cool but they are hard to find reasonable. 352's weren't a popular motor but they did make up to 360 hp from the factory & 4 speeds bolt right up as well as T-85 overdrives. A pure stock truck 352 is pretty wimpy though. If it's a later model 6 it may be a 300. That would be really cool. You've got the makings of a real nice ride there.
  20. MrHavard
    MrHavard
    Thanks Customline. I thought about running the 6 at first, and we did get it running. Im just afraid of dumping money into an engine that sat for 25 years and then have it blow up on me. Mid-Fifty makes a cross member for 352-390s that I am looking at, but Im not sure if the 352 and the 4 speed have the same bolt pattern.
  21. MrHavard
    MrHavard
    Finally got a chance to work on my truck this weekend. The frame was power washed and I was able to get the axle and leaf springs out.
  22. MrHavard
    MrHavard
    Painted everything with Por-15. When I get back into it I am going to go back over it with the ch***is top coat.
  23. chaddilac
    chaddilac
    Looks good!! I just painted the rear part of my buddy's 58 chevy pu yesterday!!
  24. MrHavard
    MrHavard
    Thanks, Im pretty happy with it so far. Next Im pulling off the front clip and taking the 223 and 4sp out. Ill be washing and painting the front portion of the frame. Then tackling the cab.
  25. mastergun1980
    mastergun1980
    from Alva OK
    I think the 352 is a cool idea. I really like y-blocks but the fe is a cool engine, and the 352 gets overlooked far to often.. oh I like 56 ford trucks.
    Here's my 56 f-series
  26. MrHavard
    MrHavard
    The 352 just got back from getting baked at the engine shop. looks like it needs to get bored to 60 over.
  27. MrHavard
    MrHavard
    Got a chance to work on the '56 this weekend, but didn't get too much done. I took my rear leafs apart and had the main eyes reversed. I only had time to get one of the leaf packs cleaned and painted, we also chisled the rivets off the front hangers on the rear, they're getting flipped upside down and raised to the top of the frame. I think I'll also be getting some extended "Y" Hangers. I took an hour or so to s****e old grease and dirt off the Dana, but I didn't have a chance to de-grease and power wash it yet. It needs the front seal replaced and probably the bearings and axle seals too. Sorry for the pics, instagram!
  28. Blake84
    Blake84
    I love this truck! If you look at my build thread I have the 223 inline 6 I just cleaned painted rebuilt top end redid engine bay and I love the 223! What exactly are your plans? I hope you don't paint it and you drop it with some nice wide white walls make the interior and the engine bay Beautiful and people will think it's an old truck and when you open the hood BAAAAM clean as a whistle! You rewiring it? If so I just did a rewire with speedway 12 circuit 12v kit for like 150 bucks and it worked great!
  29. Grumpy
    Grumpy
    from NE Ohio
    Great truck!
    I want a 56 really bad.
    Missed out on a super clean Nevada truck a few months ago.
    Watching your progress
  30. Hdonlybob
    Hdonlybob
    That is one cool truck!!
    Good for you....
    And yep, me too says leave the patina !!
    Cheers....
