picked up another piece for a dodge roadster today
Discussion in 'The Hokey Ass Message Board' started by hellsgaterods, Sep 2, 2013.
  1. hellsgaterods
    hellsgaterods
    I bought a '25 dodge cowl and grill shell at an auction a couple years ago and to day I picked up a '20 dodge roadster back half, they're close enough I can make some doors and have a roadster body, body isnt too bad for its age. I worked a little on the trunk lid today, as you can see in the second pic the inner rail was twisted, turned, spun and down right anything but straight. I popped a few spot welds and a few minutes in the vise with a pipe wrench and hammer and now it fits really good, got it all clamped in to weld fast tomorrow
  2. F&J
    F&J
    I hope you can deal with the width difference at the sill level. The older cowl tucks under to match the older roadster back you have.
    I have pieced a couple of pre 24s together for a friend near here. He says the early cowls/doors are very easy to find?
  3. hellsgaterods
    hellsgaterods
    F&J looks like it wont be hard to match up, I meen after all its just metal right? a little cut here a little weld there and bango its a roadster, lol Im not sure how hard doors would be to find, Ill probably just fabricate them up, I think itll be easy to blend the two different years that way.
  4. F&J
    F&J
    The doors for the early version have rounded lower corners at both the front lower and back lower. So, your homemade "blending" doors will be a rounded at rear and straight at front edge
    I never had to try the swap you are doing. The guy did have me put a rusty woods-found cut off rear roadster turtle piece onto the back of a 21? cut off roadster. He did not even know why that back was a bit different, but where the cuts were,( just in front of the rear fender) it fit pretty decent
    yep, it's just metal...and no wooden sills, which is better for me.
