Technical Picking The Right Brake Master Cyl?
Discussion in 'Traditional Hot Rods' started by thegearhead, Oct 7, 2020.
  1. thegearhead
    thegearhead
    So i finally got a reverse swing arm ***y for my 50 Crosley project and i'm not sure what size master cyl i should be running. The set up is disc/drum. Rear wheel cyl are 3/4. Small style calipers in the front but it's a small car haha. The calipers originally came off a car with a 13/16 bore master cyl but it was a boosted master and mine will be manual. So should i aim for a larger bore 7/8 or?
    ps my pedal ***y will be supported more just up for testing right now.
    Don't hate on my gas pedal haha
  2. BJR
    BJR
    Larger bore will give you a harder pedal as it will move more fluid. Smaller bore will give you less fluid movement with a higher pressure.
  3. There is actual math to determine master cylinder bore size or you can email or call Wilwood tech support with info related to your question. Pedal ratio, along with sizes for each brake piston will help them determine what the best master cylinder diameter is (generally). Their contact page is here.
  4. scrap metal 48
    scrap metal 48
    Smaller bore will mean less pedal pressure if you're not using power brakes... Larger bore will take a strong leg to stop unless you're using power ***ist....
    rockable likes this.
  5. goldmountain
    goldmountain
    How about pictures of your Crosley for those of us with little cars?
    AHotRod likes this.
  6. Elcohaulic
    Elcohaulic
    Pedal ratio get as much leverage as possible then figure your master.. 1 inch might be the ticket..
    fauj likes this.
  7. thegearhead
    thegearhead
  8. goldmountain
    goldmountain
  9. thegearhead
    thegearhead
    Thanks and getting there and its a s10 efi 4 cyl with 5 speed. wanted to go older iron duke but there's nothing like that around me anymore do to s****pers.
  10. goldmountain
    goldmountain
    Sorry for derailing your brake question. I have a '34 Austin and whenever I find anyone with a small car, I just have to poke my nose in.
    seb fontana and Truck64 like this.
  11. seb fontana
    seb fontana
    from ct
    We don't mind!
  12. thegearhead
    thegearhead
    It's ok don't blame ya i do the same and i never heard of Austin just Austin mini haha it's a 1934?
  13. thegearhead
    thegearhead
    Sweet CC!! ! i just installed a front clip of a cc on my shop. I see you're in Ct you know Ted Dellacamera?
  14. goldmountain
    goldmountain
  15. jaracer
    jaracer
    Going to a 7/8 will make the pedal harder to push. You need to go the other way if you aren't using a booster or try 13/16 to start. Like others have said, contacting Wilwood would be your best bet.
