pics finally dropped 64 f100
Discussion in 'The Hokey Ass Message Board' started by malkintent, Sep 1, 2009.
  1. malkintent
    malkintent
    bttt
  2. Ruiner
    Ruiner
    Blocks on the front? I didn't see any in the pics...now I gotta go back and look at the pics again...
  3. malkintent
    malkintent
    on either side of the axle
  4. Ruiner
    Ruiner
    Yep, I got it now, I just ***umed that was just built into the axle from the factory until I looked closer...I thought the dude was referring to drop blocks up front...
  5. Kustom7777
    Kustom7777
    from Austin, TX
    tapered shims will help correct the bumpsteer issue, , , speedway sells 'em
  6. 49ratfink
    49ratfink
    that is one cool *** truck. I would have left it alone, but lowering is cool too.
    I'd give it the killer "big and little" rake with cool dog dish hubcaps.
    when people ask how it rides tell them it rides as good as I want it to look.
  7. malkintent
    malkintent
    what you said!!
    dog dish is the plan
    n i dont mind bump steer, its better than my jacked up 67 bronco!:D
  8. malkintent
    malkintent
    i wish i lived out there again!!
  9. 49ratfink
    49ratfink
    I'm no suspension guru but I think you need to modify the steering arm on the back of the spindles rather than the drag link. someone who knows something about this should be along shortly to correct me or agree.
    hey... what's that in your avatar? you ought to be working on that.
  10. malkintent
    malkintent
    was a thing i was gonna do, now on to others, i just picked up a model t frame
  11. Unibodyguy
    Unibodyguy
    Really like the stance before and after. You said you used a Mor-Drop axle?? Didn't know they made any for those year trucks. Unless you adapted it from something else. I have 2, 61 Uni's and a 57 F100. I want to do this to the 57 and also drop the rear as well but with out bags.
    Michael
  12. malkintent
    malkintent
    i used the stock axle just put it ontop of the spring,
    i didnt want to go to low, n i hate clipped trucks
  13. malkintent
    malkintent
    this is the truck i modeled it after,
    i liked the stance
    grill
    moon tank
    just wanted a little less drop
  14. Ayers Garage
    Ayers Garage
  15. malkintent
    malkintent
    im going to c notch the frame and raise the rubber ones
  16. FoMoCoPower
    FoMoCoPower
    Careful of using those "big truck" exhaust manifolds you speak of,they did not have the same bolt pattern as the y-blocks used in cars and light trucks.
  17. malkintent
    malkintent
    the ford yblock ones of the ford motors do.
    the lincoln truck motors have off set bolt holes
    thanks for the tip though!!
  18. man that's a nice looking ride!
  19. malkintent
    malkintent
    has anyone else used or fabbed in econoline headlights?
  20. Ruiner
    Ruiner
    Did you drill a locating hole in your front axle for the leaf spring pack locating bolt? I'm just trying to walk through the front axle drop in my mind in case I'm lucky enough to find one of these trucks...did you remove any leafs on the front or back?
  21. Ruiner
    Ruiner
    Oh, and when are you gonna drive that POS up here so I can pinstripe it? :p hahaha...
  22. malkintent
    malkintent
    yeah drilled a hole n when i get back from madison, ill some cash then.
    i want the center of the hood striped and the tail gate, so rock on!
  23. tee joint
    tee joint
    hey there nice truck......i just picked one guy lost interest in. i really like it so far. mine is a 61,with a 351 in it. nice truck.............
  24. oldiron73
    oldiron73
    from WISCONSIN
    Nice job-Looks real nice!
  25. zimm
    zimm
    from iowa
    where did you get the front U bolts?
  26. malkintent
    malkintent
    local salvage yard, had to tweek em but, 4 sets for $50 new with bolts
  27. srosa707
    srosa707
    from Sacramento
    How did you drop the front?
  28. Ruiner
    Ruiner
    Learn to read and look at the photos...he put the front axle above the front leaf springs...
  29. srosa707
    srosa707
    from Sacramento
    HA, OK dude. I didnt notice he said that. Thanks though.
  30. VonZacho
    VonZacho
    from napa, ca
    :D:rolleyes::cool:
