Technical Pics of your front shackles with dropped axles
Discussion in 'Traditional Hot Rods' started by Roothawg, Nov 1, 2014.
  1. Roothawg
    Roothawg
    I installed a Posies reversed eye spring on my 4" dropped CE axle. With no motor, tranny or sheet metal installed the ends of the springs are touching the spring perches on both sides.
    In theory, I would think that as more weight is added, it would push harder on the spring perches preventing it from rotating and basically riding like a buck board.
    Any input on this?
  2. scrap metal 48
    scrap metal 48
    Let's see pics of your set up...
  3. Roothawg
    Roothawg
    Trying...hang on....
  4. Sounds like the spring is too wide for that model axle. What are your centre to centre measurements, perch bolts and king pin? JW
  5. TagMan
    TagMan
    Here's the pics of a CE set-up on my '36. Sorry for all the dust - it's a work in progress...... The engine is in the car, but no front sheet metal, radiator, bumper, etc.
  6. Heres my 4''dropped axle on my T, 47 1/2 and 36 1/2 (king pin and perches) JW
  7. Root,this is a photo of my Deuce pickup frame,Chassis Engineering axle,,the shackles do look odd with no weight. HRP
  8. Here's one more to look at. I assume you want reference to 32--36 style axle? Hope this helps..Tim 003.JPG
  9. Roothawg
    Roothawg
    Try this. It acts like the spring is too long to me. It measures 35.5" from center to center.
  10. With no engine the shackles should be pulled in to the center at nearly a straight line. Your spring is on top of the hanger and it should be below the hanger. The springs "hang" your hanger is acting as a "holder upper"
  11. Roothawg
    Roothawg
    The other side. I will admit that this is the first time I have ever used these little triangle hootis........not sure how they are supposed to look. It apears they rotate but these seem to only fit one way.
  12. You need to flip the shackles down and you should be ok !! JW
  13. From the top down
    Hanger, stud inside, spring
    Flip shackles and that will fix your sprimg but the studs will be outside.
    You'll need to undo the shackles and reset them to get the stud inside
  14. Root,you just need to flip the shackle,If you use a crowbar you should be able to pry against the spring eye and the perch,,the spring need to be below the perch. HRP
  15. Pewsplace
    Pewsplace
    I think he is correct. Look at the two photo attached.
    Spring hangs below shock mount.
    Spring hangs above shock mount.
  16. Roothawg
    Roothawg
    I started to do that and it felt REALLY bound up. That's when I decided to confer with the resident experts. Haha
  17. It will feel hard as its a lot of tension to overcome. JW
  18. Interesting to see how this comes out, I have the same set up CE axle with '37-'40 bones, 37-3/4" perch eye centers and am thinking about a different spring.
    Was the 35" spring what Posies spec'd for your set-up?
  19. model.A.keith
    model.A.keith
  20. Roothawg
    Roothawg
    Ok, boys and girls, I am feeling kinda dumb about now……..
    I jacked up the front end and put a crow bar on it and with quite a bit of force it broke over center and it remedied itself. Now it actually rebounds like a real front end. I knew something was up. PLus it dropped it down where it should be. It looks much better and feels right now.
    I'll add some pics when I get a chance.
    Rich, it was an off the shelf spring for a 35-40 Ford.
    Thanks guys.
    Viva La Hamb !!!!!!!
    26 T Ford RPU likes this.
  21. jseery
    jseery
    from Wichita KS
    LOL, that is a funny one. Amazing how things work when there put together correctly!
  22. A Rodder
    A Rodder
    I see that all the time on tandem axle trailers that come to my shop, the shackle links get inverted below the rocker arm. Everything binds up when that happens.
    Can you post a pic of it being correct now?
    There is a little question of where the lower shock mount will be. You may have it correct angle wise, but be upside down - putting the shock mount in the wrong spot elevation wise.
  23. When I used the Chassis Engineering split bone kit on my 39 Ford convertible I mounted my shackle mounts like Root has them oriented that way it gives the shock slightly more room once he flips them to travel. HRP
  24. I would like to see a view including the top mounts to see how the shocks fit around the sway bar. JW
  25. Roothawg
    Roothawg
    Probably can't see much. It's kinda dark out there.
    IMG_1385.jpg The sway bar isn't connected yet.
  26. Roothawg
    Roothawg
  27. Cheers, looks good. JW:)
  28. 3wLarry
    3wLarry
    from Owasso, Ok
    the planets have aligned...I learn something new everyday...thanks to all.
    kidcampbell71 likes this.
  29. The 41Dude
    The 41Dude
    Got to love the H.A.M.B.
  30. Pewsplace
    Pewsplace
    Looks good to me.
