Technical Pics of your front shackles with dropped axles
Discussion in 'Traditional Hot Rods' started by Roothawg, Nov 1, 2014.
  1. flamedabone
    flamedabone
    YEA!!! Glad you got it.
    Is that a 35 truck? Gonna need some pics...
    -Abone.
  2. Roothawg
    Roothawg
  3. RICH B
    RICH B
    Looks a lot better with the shackles flipped the right way; but would have thought they would have been sitting flatter without the weight of the engine etc.
  4. verde742
    verde742
    are you sure the shock mount "thingie" doesn't need to go to the other side of the car?
    Not sayin' it very well, but if both of them were changed to other side ? just sayin'?
  5. Roothawg
    Roothawg
    Not sure. I'll have a look at it when I get some more time.
  6. 19Fordy
    19Fordy
    40 Ford with 4 inch dropped axle and Posie reversed eye spring.
    Shackle should be at about a 45 degree angle.
  7. Atwater Mike
    Atwater Mike
    I used to make the 'triangle' shackles to mount shocks, not my idea; I stole it from a '34 in the 'Little Pages', back around 1953! Glad to see it back, lots better than that ****eyed add-on 'stud' below the spring hanger. (and that long, soft repro hanger!)
    Some guys like 'em, but every one I see is crooked after a few miles...or ends up welded onto the lower yoke of the wishbone...the ones with keyways sheared off, unless the shocks were so soft they were ineffective.
  8. verde742
    verde742
    not applicable. wrong subject. IMO
  9. verde742
    verde742
    not on subject,, IMO
  10. 26 T Ford RPU
    26 T Ford RPU
    verde742, how on earth was my post not applicable and wrong subject???? What was the heading?? The photo I posted show front shackles on a dropped axle, that photo alone would have shown the OP what the problem was with his front shackles or is it just because the spring is in front of the axle, we didn't know that then but it would have still sorted the situation out.......which it did. Cheers for your concern.o_O JW
    RICH B likes this.
  11. verde742
    verde742
    OK, take me off yer list. I thought about the 3rd picture down it showed a '36, which have spring in front of axle: Then comes yers with spring on top.... But then I am old.
  12. I'm thinking if you used a stock off the shelf 35-40 spring with a narrow CE axle that the the spring is just still too big
  13. 26 T Ford RPU
    26 T Ford RPU
    What is the difference between the perch bot centres on this CE verses a 35-36 axle?
    verde742..we're good. JW:)
  14. okiedokie
    okiedokie
    from Ok
    35-36 axles have 36 1/2" perch centers according to Sids site. CE says there are 35". When I ordered my CE axle I was told they were now shipping SoCal axles, which were the same as theirs. However the axle I received is 33 1/2" . Certainly moves the bones farther in for tire clearance. It is a 47" wide axle which is the same as theirs. I can vouch for the fact that Speedways 35-40 Ford front 4 bars will not work with the SoCal axle, if that is what I have. No logo on it.
  15. Soviet
    Soviet
    Look at these two again. Wrong or right aside, the shocks will be different as the compressed and extended lengths look to vary by over an inch.
  16. Roothawg
    Roothawg
    I haven't thought about this for a while, I've been on other parts of the build. I will revisit this soon.
  17. DDDenny
    Just to stir the pot a little!!!
    Here are two shots of my roadsters spring/shackle attachment.
    Anyone recognize this setup?
    Hint: this is only used on one side, the other side is your typical shackle arrangement.
    Now this is where you old dirt trackers can give everyone an education on it's merits,
    explained much better than I can I'm sure.
  18. 26 T Ford RPU
    26 T Ford RPU
    Yip, the dead perch, used on the L/H side of the front spring ( for L/H turning) to prevent shackle swing. JW
    dana barlow likes this.
  19. krylon32
    krylon32
    from Nebraska
    I ran a dead perch on my deuce roadster back in the 80's worked great. That roadster was kinda unusual for the times as it had the dead perch front and 1/4 elliptic s in the rear. One of the best driving and riding roadsters I have built.
  20. The shackle is facing in the wrong direction, spring in front the shackle should be dropping down. A way to remember this is that when you want to lower a car with spring in front (or behind on the rear) to install longer shackles thus dropping the spring eyes lower in relation to the axle center line.
  21. chiro
    chiro
    So who makes that "triangle" shock mount thingy that replaces the end plate on the shackle and will that work on an AV8 with drop axle instead of welding a bung to Henry's steel?
    thanks,
    Andy
  22. I recognize the setup I think its called a dead perch or something like that, you have one dead side and the other has a shackle. I can never remember which side is dead though, I want to say steering box side but I am no doubt wrong about that.
  23. HOTRODPRIMER
    HOTRODPRIMER
    This was my old mordoor sedan. HRP
  24. HOTRODPRIMER
    HOTRODPRIMER
    They make two versions of the dead man perch,the one that DDD posted and this type that is show on the last post.HRP
  25. okiedokie
    okiedokie
    from Ok
    Ch***is Engineering.
  26. 40Ford!!
    40Ford!!
    Since you all are on the topic......I think my shackles are at the wrong angle.? In this picture I do have the vehicle on jack stands but if it's on the ground, my shackle angle only slightly angle OUT. I want the front height raised anyway so I was going to swap out the "reverse eye" with a "regular eye" spring. If I'm hearing you all correctly, my resting shackle angle should be 45 degree facing inwards.....right? I know Posie has a method (King Pin center to center and Spring Perch center to center) to measure so I will follow that.
  27. 26 T Ford RPU
    26 T Ford RPU
    Your spring is too wide. JW
  28. mike bowling
    mike bowling
    I know it ain't Vern Tardel, but the "Speedway" catalog has some charts referencing perch centers and spring length. Also says that under load, shackles should sit at 40-45* . I don't have the ac***ulated knowledge of some of youse guys , so this helped me out. Good luck with it- your avatar is freakin' KILLER, Mr . Roothawg!
  29. clem
    clem
    maybe a bit late, but dont forget to put the nut back on the perch bolt!
  30. ago
    ago
    from pgh. pa.
    The opinions out today, say the front panhard works better than a dead perch. Also with a front panhard the shackle angle is not as critical. More vertical angle on the shackle lets the leaf spring work more freely. So if your shackle ends more straight up and down, it should not matter much.
