Pictures needed of 42-48 flathead fan mounts
Discussion in 'The Hokey Ass Message Board' started by hemifarris, Dec 8, 2007.
  1. hemifarris
    hemifarris
    I'm going to replace the electric fan on my roadster with a factory fan blade. I'm running a '48 flathead with a dual carb intake. With this intake I'm not able to run a fan/generator combo as there's no room for the generator in its stock location. Does anyone have any front pics of a flathead with a double crank pulley and a fan mount in the generator stock location? I'll run the generator on a head-mounted brkt.Thanks,Mike
  2. J'st Wandering
    J'st Wandering
    I do not have the picture that you are looking for but what you are saying should work. I have a the generator mounted in the stock location and have the fan mounted below it running off a separate belt. With mine, I should be able to move the generator over to the head and the fan would not be affected. Or did I miss something. Neal
  3. Bruce Lancaster
    Bruce Lancaster
  4. Bruce Lancaster
    Bruce Lancaster
  5. hemifarris
    hemifarris
    Bruce, that's the fan/mount ***embly that I bought so I guess I'm on the right track. I was hoping to get a pic of how guys are mounting their generator/alternators off to the side. Speedway sells a right side head mount for the original type generator or powergen...Thanks for your input..............Mike
  6. Bruce Lancaster
    Bruce Lancaster
    for early flatheads, traditional R&L offset brackets are very different, and on some applications like a '40 Ford only one works. One kind mounts the generator perpendicular to the head, the other mounts it perpendicular to the ground. Generator location ends up quite a bit different in relation to engine centerline.
