Technical Pictures of 1932 ford sub rails
Discussion in 'Traditional Hot Rods' started by Colton Leigeb, Mar 2, 2021.
  1. V8-m
    V8-m
    from Alaska
    @glennpm Thank You,
    I can't read some numbers and words.
    Not realy sure where I should strat with those numbers. I don't know the total length of the rocker panel because starting from point-zero means I dont have body panels yet.
  2. glennpm
    glennpm
    I can give you more in a few days.
    V8-m likes this.
  3. A Boner
    A Boner
    Great thread…should be helpful to many. Hopefully more pics and comments will continue to be added to help save all these rusty gems that fortunately keep surfacing!
  4. glennpm
    glennpm
    Hi V8-m,
    I measured, took and pulled together some photos this morning.
    Nailhead Jason and V8-m like this.
  5. V8-m
    V8-m
    from Alaska
    @glennpm Thank You vey much. It was a lot of work with dis***embly and measuring. We appreciate your help.
  6. glennpm
    glennpm
    You’re welcome. Please post any drawings and your results.
    Glenn
    V8-m likes this.
  7. A Boner
    A Boner
    Bump
    V8-m likes this.
  8. V8-m
    V8-m
    from Alaska
    Some pictures for reference "stolen" from the HAMB
    Nailhead Jason likes this.
  9. V8-m
    V8-m
    from Alaska
    So finaly i started to make my own subrails. I prefer original style therefore I made holes on the inside part. Even if no one will see it..... I know they are there...
  10. The37Kid
    The37Kid
    Rails look great, I like seeing new parts made that look like the originals. Showing the tools involved would be nice. Bob
    V8-m likes this.
  11. glennpm
    glennpm
    Looking good
    Glenn
    V8-m likes this.
  12. V8-m
    V8-m
    from Alaska
    Realy nothing special involved. Just angle grinder, hole saw, tig welder, brake press
    The37Kid likes this.
  13. V8-m
    V8-m
    from Alaska
    I'm back...again...
    Can somebody check the distance between center of the hole and midle part of subrail ?
    At what distance from the frame the subrail follows its shape. Is the distance the same throughout or does it change?
  14. 19Eddy30
    19Eddy30
    from VA
    On Mine & others I have been around ,( none channeled )
    There is a gap 1/4 - 1/2 Between sub rail & frame
    From firewall to p*** rear wheel .
    V8-m likes this.
  15. V8-m
    V8-m
    from Alaska
    Started welding...
    Just Gary and 29EHV8 like this.
  16. V8-m
    V8-m
    from Alaska
    29EHV8, Just Gary, hotcoupe and 3 others like this.
  17. nrgwizard
    nrgwizard
    from Minn. uSA
    Wow; Those're nice...
    Marcus...
    V8-m likes this.
  18. Nice work…..Start a build thread…
    29EHV8 and V8-m like this.
  19. glennpm
    glennpm
    You did good!
    V8-m likes this.
  20. V8-m
    V8-m
    from Alaska
    Thanks! Yes I'm thinking about that.
    29EHV8 and Irish Mike like this.
  21. Nacifan
    Nacifan
    This thread is just AMAZING !!!
    I need floor pictures of '32, 2-Door and 4-Door Sedans. Did Henry make the Sedan floors all Steel except just ahead of the front set riser ???
  22. 19Eddy30
    19Eddy30
    from VA
    Yes on 2 door,
    Not sure on 4 door ,
    I would say yes also
  23. The Lucky Star
    The Lucky Star
    from Utah
    Here's a Tudor. We'll be doing a coupe conversion with it. I'll upload Fordor floor when I can. If anyone has similar photos of 5w please upload them.
    29EHV8 likes this.
  24. The Lucky Star
    The Lucky Star
    from Utah
    Here are a few more.
    29EHV8 likes this.
