pictures of spring over frame axles
Discussion in 'The Hokey Ass Message Board' started by SinastirSpeedShop, Oct 25, 2009.
  1. I am looking for some pictures of spring & axles over frame setups.
  2. olskool34
    olskool34
    a pic of my old 36, spring and axle over frame
  3. What is the name of the style where you have two leaf springs one on each frame rails?
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    Semi-ellipticals if a full spring is on each frame rail.
    Quarter-ellicticals if a "half"-spring is used on each frame rail.
    The Ford way is called transverse spring mounting.
  5. Fogger
    Fogger
    If full length springs are used with one end mounted to the frame and the other with a shackle it's referred to as parallel leafs. If you use half a leaf spring on each side they are still parallel but would be called quarter elliptic springs. The FOGGER
    Pasadena beat me to it!
  6. rev616
    rev616
  7. Dirty Dug
    Dirty Dug
    Try searching "under slung".
  8. simon g-s
    simon g-s
    Heres mine, I'm too cheap to buy much so all home built.
  9. Thanks
