pilot bushing/bearing stuck? help please
Discussion in 'The Hokey Ass Message Board' started by Ornery37, Sep 13, 2007.
  1. Ornery37
    Ornery37
    from Texas
    I broke my trans (sbc 350 to sag 4-speed) so pull it out and since it is out, I am going to replace the clutch, pressure plate, and pilot bushing.
    But it is stuck! Is there a removal tool? Or a magical way of getting it out? In the past I was able to pull out with my fingers.
  2. old beet
    old beet
    To remove pilot bushing....Pack bushing with grease, make a wood dowel just big enough to fit in hole. Put gl***es on, insert dowel and hit with BFH. It has always worked for me!!!.........OLDBEET
    Bubba1955 likes this.
  3. Deuce Roadster
    Deuce Roadster
    I have always used the grease method ...
    Pack the hole with wheel bearing grease and then drive the input shaft into the hole. Refill hole with grease and repeat as often as needed to get the bushing out. It takes a while ... but it does work.
  4. Markgyver
    Markgyver
    I used to work at a parts store and we rented a tool to remove it. I was a slide hammer with two little fingers the gripped the bushing.
  5. nexxussian
    nexxussian
    If you can't get the dowel to fit tight enough, KD makes a tool that threads into the bushing (tapered thread) that has a grease Zerk in it that lets you use a grease gun to do the same thing. 12 bucks IIRC, usually available at NAPA.
  6. Ornery37
    Ornery37
    from Texas
    cool! thanks all!!!
  7. flt-blk
    flt-blk
    from IL
    Most clutch alignment tools you can remove the ring and use it instead of a dowel.
  8. old beet
    old beet
    O 37, let us know if it worked.................OLDBEET
  9. Tudor
    Tudor
    from GA
    I have also heard (from Green MTN Boy's old man) of just tapping the bushing and threading a bolt in. The bolt will bottom out and when you keep turning it, the bushing will come out on the threads. good luck
  10. Ornery37
    Ornery37
    from Texas
    the grease did not work. And no kidding when you said put gl***es on.
    I will try treading and using a bolt.
  11. alchemy
    alchemy
    If the grease didn't work, you didn't have a tight enough fit in the hole. Find a socket that fits good, put an extension on it, fill with more grease and give it some taps with a hammer.
    If the fit is good, you won't need the gl***es.
  12. mtkawboy
    mtkawboy
    If youre in the pits at the NHRA Nationals , peanut ****er works too:D
  13. Topless Ford
    Topless Ford
    Advance and auto zone both let folks use tools for free around here. I just buy a roll of shop rags and ask for the proper tool. I believe I got the bushing puller from Auto zone.
  14. CptStickfigure
    CptStickfigure
    from Urbana, IL
    Keep at it. I tried the grease method and the puller method.
    The puller worked eventually, but that damn bushing put up a fight.
  15. revkev6
    revkev6
    from ma
    got the one out of my SBC with the grease and dowel method. I cut the dowel (a shovel handle originally) on my steel lathe until it was just bigger than the hole. makt sure you have to hammer it in to the bushing or it won't seal good enough.
  16. GreenMtnBoy
    GreenMtnBoy
    Worked several times for me (dont ask):eek:
    Get a big bolt, taper the end, cut 3 grooves in it like a tap, tread it in with some lube. Once it bottoms on the crank the bushing comes right out. My Dad is a genious!
    By the way, there are 2 different sizes of sbc pilot bushings.
  17. ss34coupe
    ss34coupe
    This method worked for me, taking the pilot bushing out of a 53 Cadillac 331 crank. The bolt threaded the bushing, and when the end of the bolt hit the crank, I kept turning the bolt and the bushing started to come out. Here is a pic of the removed bushing still on the bolt. Would recommend lubricating the bushing well before putting the bolt in. IMG_0644.JPG IMG_0646.JPG
  18. tommy
    tommy
    If you are trying the grease method, stand off to the side so that the flying grease doesn't ruin your day.
    I use a hack saw blade to cut it out. When you get close, collapse it on itself and it will fall out. Takes longer but a lot cleanlier.
  19. You can also take moist shop paper towel, and pack it into the pilot bearing hole using a wood dowel , keep packing until the moist shop paper towel fills the pilot beating hole and is packed tightly.
    Then using the wood dowel hit a few times, pack more moist shop towel and repeat. This method will slowly drive the pilot bearing out, and is a bit cleaner then grease
    Let us know how it goes
  20. Barsteel
    Barsteel
    from Monroe, CT
    7/16 tap through and through, keep cranking till it bottoms out in the crank hole, then keep cranking...it will walk the pilot bearing out.
  21. Might be able to find a bolt that fits tightly in the bushing. If you get it full of grease and the shaft you're hitting is tight enough, it WILL come out.
